Yamaha 40HP propeller
kvan64
My Yamaha aluminium propeller says 11 1/8 x 13
What are these measurements for?
Will the 10 x 13 size be used with this motor? (I just saw a cheap SS one comes up from eBay)
Thanks
Silvertip
Honorary Supreme Mariner
Re: Yamaha 40HP propeller
11-1/8 is the diameter of the prop in inches. 13 is the pitch. Pitch is the theoretical distance the prop will push the boat in one revolution. 13P would push the boat 13 inches forward with each revolution. That is of course theoretical since the prop operates in a liquid and there is slippage. A 10 inch diameter prop would likely not be correct since the hub diameter might be incompatible with the gearcase on your engine. Then the splines might be different as well. You need some part numbers in order to tell. Generally, a prop with that much difference in diameter is not intended for your engine.
kvan64
Thank you. This would help a lot! Save me from buying the wrong one.
