yamaha 8hp problems
illman
i have a 93 model 8hp two stroke,it ran fine until i laid it in garage for 2 months,it would only run with choke on.i thought i would rebuild carb,put a carb kit in it and rebuilt fuel pump,all new lines and filter.when i got that done i tried to crank,it ran fine for about 5 seconds then quit.it will not recrank.i have fuel and fire??any help.
YAMA-TIM
Re: yamaha 8hp problems
The carbs on these motors generally have very small passages which easily become clogged with gummed up fuel and are very difficult to clear manually. I would try disassembling the carb and soaking it in a good parts cleaner overnight, this should dissolve any deposits in these very small passages and hopefully solve your problem. Also a good fuel stabilizer used during storage should prevent a repeat of this issue.
illman
fixed the problem thanks for the help.
