superfets
Thread starter- Joined
- Mar 6, 2017
- 139
This will be useful too http://www.boatfix.com/merc/Install/gas/86017211.pdf
Yes, that will most definitely be very useful. And hopefully in my near future. Thanks
No, it aligns the upper and intermediate shift shaft shoes to fwd/aft, so they slide apart. If you don't, you'll bend the shafts and/or shoes.
Chris.........
pic 1 input hsaft looks funky, a bit short
pic2 water in the bellow at one point, rust
pic3 water residue
manifold pic, crack from poor winterization
If the manifold is cracked then it gets replaced. I wouldn't bother right now with the bellows, have a suspicion that your going to be looking for another motor or full rebuild.
What do i need to do about manifold? Can we live with it like that?
Ayuh,.... IF, it's only cracked to the outside, ya could butter it with epoxy,....
Problem is the IF,....
'cause IF it's cracked to the inside, you'll kill the motor from the water leakage,....
'n it's 'bout impossible to test,... reliably anyways,...
If it's the latter, does anybody got one kinking around that they would like to sell me? Or know where to look? I thought it would have been easier finding one.
Ayuh,... Best place to find a good motor, is in a Rotten hull,....
Ya oughta be able to buy a Rotten boat, complete for under $1500....
Search yer local craigslist for a Rotten donor boat,....
And WTF does "[FONT="]Motor needs a fuel pump and some TLC, no obvious cracks in block or manifold so i assume it shouldn't take much to get it going." mean! Lol.[/FONT]
Ayuh,... That means ya can't start it, 'n run it to see if it's any good,...
But,...
That don't mean ya can't do a compression test, 'n see if it's got good bones, or is junk,....
Btw,... I believe you can get a brand new long block crate motor for 'bout $1500.....
You could contact Piston Ring or Custom Crankshaft and see if they have any used blocks.
They rebuild a lot of these motors. Not sure if Custom is still around.
Nix marine in east selkirk has a lot of used stuff (I'm in no way vouching for them)
Also there's a fellow in Gimli that sells used stuff that you could contact. I've bought a couple of things from him.
Here's an example
http://www.kijiji.ca/v-boat-parts-t...-starcraft-css-with-3-0-mercruiser/1208592828
We're going to be boating this spring come hell or high water.
Don't forget your waders
I know I'm bad :facepalm: but couldn't resist![]()
Ayuh,.... A quick google search, "3.0l base marine long block engine[/URL]", tells me I'm wrong,... more like $2700. or so,...
'n, No, yer right, a compression test won't tell ya 'bout a cracked block,....
That's when lookin' real closely at the block, up, 'n under the intake/ exhaust manifold is important,...
That's the wet side, 'n where they crack,...
Anywhere from 'bout a 1/4" below the head, down to the drain plug,...
There, 'n directly opposite the drain plug, on the inside oil cavity,... where ya can't see til the oil pan is off,...
Thanks. I will look into all thoes leads. I saw that one in gimili but i was too late. I'm not giving up yet. We're going to be boating this spring come hell or high water.
