T
tphoyt
reacted to
airshot's post
in the thread
Bait and Livewell
with
Like
Around my area we are experiencing hot days some near 100 degrees, the lake surface temps are 85 degrees. Have had bad experiences with...
Aug 16, 2025
replied to the thread
2005 4.3 liter Mercruiser ignition trouble
Agree Start measuring and cleaning connections. Might start with the key switch, than with the 10 pin engine connector
Aug 16, 2025
A
airshot
Bait and Livewell
Aug 16, 2025
H
Harkonnen
posted the thread
Water temp or head temp?
in
Johnson & Evinrude Outboards
So I got that dual-temp gauge from a company I won't provide with a free advertizement. Put the sensors into water pressure ports. Works...
Aug 16, 2025
ESGWheel
Cant start engine when opening throttle. Mercruiser 3.0
While there is an issue with the control / neutral safety switch I am curious as to your starting procedure. Reving a cold, just...
Aug 16, 2025
redneck joe
posted the thread
Epic launch
in
Stupid Human Tricks While Boating/Fishing
https://www.facebook.com/share/r/16rLGhkgSY/
Aug 16, 2025
U
utfyrfytr
Bait and Livewell
Wow that turned into quite the discussion. After additional research, I agree with the one pump being discontinued theory. I can only...
Aug 16, 2025
P
Pmt133
If it's dropping that low you are getting a voltage drop on the ignition side of the electrical system... either bad ground or bad...
Aug 16, 2025
redneck joe
reacted to
beta's post
in the thread
1995 Crownline 202BR Restore
with
Like
After some summer getaway time, I'm back at it. Made my fiberglass order from US Composite and found a local source with marine plywood...
Aug 16, 2025
redneck joe
Let's talk skill...
Agreed. I've had two and other than the ill fated L Drive on the 20 footer, loved them both and was very close to buying a 44 footer.
Aug 16, 2025
P
Pmt133
reacted to
beta's post
in the thread
with
Like
Aug 16, 2025
redneck joe
2025 NFL/CFB News and Nonsense
Just Can't Resist
Aug 16, 2025
S
Steve51
Bravo 3 Prop selection - other options?
Hi, his boat with identical boat and engine, clean hull and medium load was tested with various sets of test props and then the engine...
Aug 16, 2025
B
beta
Aug 16, 2025
K
kepruno
Very significant voltage drop at the + terminal of the coil when cranking. Good for a second or 2 then falls to about 4 volts. I don’t...
Aug 16, 2025
