guy48065
replied to the thread
I should add a 2nd battery...
I've had one in the back of my suvs for at least 10 years with no issues. I know about the concerns but have had no storage problems.
Aug 16, 2025
guy48065
I have always run 2 batteries in my pontoon, with a Perko switch. I've never needed the #2. I'm always wondering IF I ever need it will...
Aug 16, 2025
P
Pmt133
Don't keep the jump pack in the boat. They are good though. I've had to put out a few fires from them getting too warm in someone's car...
Aug 16, 2025
guy48065
THIS is my situation. Boat is tied to my dock 200 feet away and has a 1 year old starting battery. No starting problems in the 2 weeks...
Aug 16, 2025
nola mike
Shift cable bellows.
find a picture of the grommet. I don't think anyone has any idea of what this part is.
Aug 16, 2025
nola mike
Stretched Shift cable. Cut to shorten?
the slide should have some play but not much. tighten the set screw and the back off a touch until the slide can rotate freely.
Aug 16, 2025
High Fuel Pressure
There is a quad ring in there and they can get stuck. All you can do is pull and wiggle.
Aug 16, 2025
W
wengr
Still struggling with this. The original shift cable jacket would not come out through the plastic grommet. I had to cut it in order to...
Aug 16, 2025
M
MikeSchinlaub
reacted to
beta's post
in the thread
1995 Crownline 202BR Restore
with
Like
After some summer getaway time, I'm back at it. Made my fiberglass order from US Composite and found a local source with marine plywood...
Aug 16, 2025
B
badrano
High Fuel Pressure
Any special tricks to pull the fuel line out of the top cover? The pin screw is removed and the line does wiggle but it's not coming out.
Aug 16, 2025
B
badrano
reacted to
Fun Times's post
in the thread
High Fuel Pressure
with
Like
Should you pre-fill with fuel if possible, yes to help avoid pump stress / heat / early wear out… do you have to, no… with many key on...
Aug 16, 2025
T
tphoyt
Let's talk skill...
I agree. They were very popular in my area of Fl in the 80’s. They were everywhere and adorable boats of the time. The thing was they...
Aug 16, 2025
redneck joe
Random
Aug 16, 2025
Watermann
16’ supersport restoration questions
Nope, try again. ;)
Aug 16, 2025
S
saltchuckmatt
Water temp or head temp?
Yes, that's where it goes.
Aug 16, 2025
