GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
jimmbo
replied to the thread
2 stroke longevity?
You got that backwards
Yesterday at 12:53 PM
jimmbo
If you're wondering if your anti siphon valve is stuck, or clogged, here's a test....
The one on my Boat was stuck closed when I took it out the First Time. Engine had been run from a Separate Tank at the Dealer during...
Yesterday at 12:52 PM
dingbat
Interesting note on Permatex #2 While they claim chemical / solvent resistance to gasoline, they don't recommend for use where there is...
Yesterday at 12:34 PM
B
billhig
cowl air inlet on mercury 9.9.
Yes, I knew that. I replaced the gasket from the powerhead to the adapter plate and the gasket from the adapter plate to the...
Yesterday at 12:30 PM
K
kepruno
2005 4.3 liter Mercruiser ignition trouble
Agree that ‘a’ is irrelevant. Now I know. Summary: 1) followed trouble shooting flow chart to -replace distributor sensor - so I did...
Yesterday at 12:29 PM
B
billhig
Great minds think alike - I took out the grab handle insert and now I've got a huge inlet. I'm still confused as to why there is none...
Yesterday at 12:28 PM
P
peters715
No Trailer and Trim Up
I replaced the solenoid a year ago which resolved an intermittent issue with trim in general. I believe that the switch config required...
Yesterday at 12:23 PM
K
KTEC
1998 Johnson J115ELECM idle adjustment help!
Chris, thanks for the information. I ran the engine for about 20 minutes with warm water coming out of the engine but did not hear any...
Yesterday at 12:08 PM
nola mike
salt water in single cylinder
many on here have had luck with Michigan motorz. I haven't purchased an engine from them, but have bought a few parts, and spoken with...
Yesterday at 11:57 AM
C
cyclops222
reacted to
Chris1956's post
in the thread
options for boat cover supports
with
Like
Covers stretch. We need to support them no matter what.
Yesterday at 11:55 AM
redneck joe
1986 Starcraft Mariner 160
Cool deal. Keep us up to date.
Yesterday at 11:54 AM
redneck joe
reacted to
Hand Crafted Angling's post
in the thread
with
Like
I flipped back and forth on what to do with and decided to fix it up. Scraping all of the crap the previous owner had on it before was...
C
cyclops222
Mercruiser 409 engine severe vibration issue
By chance does that engine have a engine dampener on the front of the crankshaft ? Is it the correct one ? And correctly timed to TDC of...
Yesterday at 11:53 AM
redneck joe
Marine Sea Foam
Yeah what i saw in my search was low 70stop end so you might be close. 80 the PO told you prob is like mag stickers on new vehicles.
redneck joe
reacted to
Ranger09's post
in the thread
Marine Sea Foam
with
Like
I only use ethanol free with yamaha ring free in every tank. Its a 2006 motor and have no idea what the previous owner used.
Yesterday at 11:52 AM
