Superjetjim
reacted to
Chris1956's post
in the thread
Mercury V6 XR2 - Does this Stator looks bad?
with
Like
The early 90's and older Merc V6 motors had fixed idle jets. My '93 has adjustable idle jets. I would have thought your motor would...
Feb 9, 2026
C
replied to the thread
Feb 9, 2026
Superjetjim
UPDATE - so managed to water test it again yesterday. Still wont pick up in the water, it bogs. Took this video as we sprayed starter...
Feb 9, 2026
R
1960s McCulloch 7.5 hp w/ electric start above fltwheel with Serial 80355-1412
Your location ?
Feb 9, 2026
jerryjerry05
Wiring a 3 wire trim/tilt pump to throttle handle switch
In the old days: they didn't have a Trim up on the Chryslers/Forces. The outboards that had T@T usually had a heavy duty switch on the...
Feb 9, 2026
R
rjcamel2355
99 3.1l ox66 wont rev (what am i not thinking of here)
That's the only thing that makes a lick of sense to me. Exhaust pushing water away from the prop thus decreasing load and allowing it...
Feb 9, 2026
Superjetjim
Thanks Chris, yep done filter and link/sync. Didnt know you could richen the carbs up on these, outside of jet changes. Would it pick up...
Feb 9, 2026
Superjetjim
reacted to
Chris1956's post
in the thread
with
Like
Link and synch? Replace any fuel filters. Richen the idle mixture to allow easier acceleration.
Feb 9, 2026
Lou C
New Stuff on Vehicles likes/dislikes
Every so often it’s a good idea to loosen the serp belt and spin the idlers & accessory pulleys if a bearing is getting rough you will...
Feb 9, 2026
C
My '77 Merc used a solenoid on the up circuit only. The PTT control switch was pretty robust, and the wiring was heavier on the down...
Feb 9, 2026
C
Feb 9, 2026
I doubt any parts list would have the brushes. you will most likely need to visit your local starter and alternator repair shop.
Feb 9, 2026
redneck joe
2026 NFL/CFB News and Nonsense
Yup
Feb 9, 2026
dingbat
Here is the TSB for the three years prior to yours https://static.nhtsa.gov/odi/tsbs/2022/MC-10225529-0001.pdf
Feb 9, 2026
M
MikeSchinlaub
Random
Feb 9, 2026
