A
airshot
replied to the thread
1994 Starcraft Super Fisherman 170 Rebuild Help
Might be better to show the problem areas themselves. Nice looking boat, that hull style handles chop well.
Feb 9, 2026
Captndrydock
reacted to
jerryjerry05's post
in the thread
Wiring a 3 wire trim/tilt pump to throttle handle switch
with
Like
In the old days: they didn't have a Trim up on the Chryslers/Forces. The outboards that had T@T usually had a heavy duty switch on the...
Feb 9, 2026
Captndrydock
reacted to
Nordin's post
in the thread
with
Like
As Scott says, you need to operate the T&T with to relays and control them from the switch in the remote control handle.
Feb 9, 2026
Captndrydock
reacted to
Scott Danforth's post
in the thread
with
Like
the switch in the handle is operating the contactors which operate the motor. no way to run motor wiring thru a switch small enough to...
Feb 9, 2026
S
ShoalSurvivor
Alpha One Gen II - bell housing bushing/seals - updated design?
Perfect. Thank you! Now the more important question - should I replace the bushings, or just the seals? There is no "slop" in the...
Feb 9, 2026
S
ShoalSurvivor
reacted to
Fun Times's post
in the thread
with
Like
Being your serail number is 0L517680 which is above 0F094775 you still have ordered an updated design kit that will work just fine as...
Feb 9, 2026
WIMUSKY
2026 NFL/CFB News and Nonsense
Worst SB in quite awhile....
Feb 9, 2026
M
mauro.
posted the thread
Boat value
in
Boat Topics and Questions (not engine topics)
I am wondering what you guys figure this Setup is worth that I have attached below. Thanks in advance Mauro
Feb 9, 2026
B
bnorth1
I appreciate what everyone has said. Does any one have pictures or a thread that can give me an order to do it in? Also, here is a...
Feb 9, 2026
Superjetjim
reacted to
Dukedog's post
in the thread
Mercury V6 XR2 - Does this Stator looks bad?
with
Like
look here for a build date stamp.. may not be very readable but its there on tha block somewhere... should be area "behind tha advance...
Feb 9, 2026
Superjetjim
Ah thanks, found it!
Feb 9, 2026
Dukedog
Feb 9, 2026
Superjetjim
Hi Chris, Not checked the flywheel magnets in fairness, will pull and check that, easy thing to do. It runs a little better with the...
Feb 9, 2026
Dukedog
chris, his motor has tha older WH's that have been changed which do not have anyway ta change idle except jetting.. his motor came with...
Feb 9, 2026
R
Flywheel magnet checked ?-----Recheck all wires from switch boxes to the coils.-----Sounds like it is running on 4 of 6 cylinders.
Feb 9, 2026
