R
replied to the thread
Water pressure valve replacement 2000 evinrude 4stroke
You are making a MISTAKE reading the parts diagram.-----The water pressure valve is NOT located where you think it is !
Feb 19, 2026
Superjetjim
reacted to
Dukedog's post
in the thread
Mercury V6 XR2 - Does this Stator looks bad?
with
Like
not a clue?.. what ever it is it should not have been there............... tha only thing on tha "outside" of tha tube will be tha...
Feb 19, 2026
T
TnTommy
posted the thread
in
Johnson & Evinrude Outboards
New to the boating world and have been trying to get this 2000 evinrude 50hp 4stroke/ Suzuki ready for the summer I’m trying to do any...
Feb 19, 2026
Dukedog
Feb 19, 2026
J
jlh3rd
2003 150 Sport - Old DECALS / STICKERS?
Google's your friend.
Feb 19, 2026
jimmbo
2020 DF35A 30hp conversion.
An increase in Horsepower from any given Displacement, requires raising the Rpm at which the Hp is attained by shifting the Torque Curve...
Feb 19, 2026
Superjetjim
Feb 19, 2026
Superjetjim
Hi Dukedog, any ideas what this is, it was spinning round the outside of the water tube that runs up the leg to powerhead. Made of thin...
Feb 19, 2026
A
airshot
reacted to
rodsnguns's post
in the thread
Lubricate new water impeller rubber ?
with
Like
Since our yays and nays pretty much were even, we agreed upon "to each his own" . I take the thin film route, but I am an over doer...
Feb 19, 2026
Welcome Don't know for sure but with the boat not being that old, you should be able to contact Whaler Whaler
Feb 19, 2026
E
Earl Cordova
Quick silver 90w gear oil okay for 60hp
Very little difference between 80w-90 and 90w, so why not ?
Feb 19, 2026
Texasmark
can you remove the top drain plug screw from a lower unit and re instal it with a new washer ?
Not knowing your experience with the subject, the engine needs to be vertical. The drain and vent screw(s) need to be removed. The...
Feb 19, 2026
Texasmark
Why not. Oil is there to keep metal off metal. The harder (better) the film the better the protection. In things that have to pump...
Feb 19, 2026
Mercruiser 350 MAG MPI
What is the serial number? The cam sensor can be replaced but right now I don't see it as causing excessive fuel. This that can cause...
Feb 19, 2026
matt167
Yes, but I think I’ll get more bottom end out of it. The old 40hp twin actually wasn’t much faster if at all than the 25hp is, but the...
Feb 19, 2026
