  • tpenfield
    I finished off things inside the extension and moved over to the transom. I got it set in place and will be doing fillets tomorrow. ...
  • Superjetjim
    Further update. Installed the new impeller and housing - water cooling is now sorted and running a strong pisser out of head and poppet...
  • D
    DeepCMark58A replied to the thread SNOW Common Sense.
    You know they make machines that blows snow out of the way, many are electric start.
  • tpenfield
    tpenfield replied to the thread 1994 5L EFI Volvo penta.
    I've had starter solenoids (I think they are actually referred to as slave solenoids) be working 30 minutes before launch and then at...
  • FLATHEAD
    FLATHEAD replied to the thread SNOW Common Sense.
    Sounds like I’ll be spending considerable time on this Monday afternoon.
  • B
    Thank you for responding. I now recognize the name. You've responded to other threads I've started, which I appreciate. Simple update...
  • Bob_VT
    Bob_VT replied to the thread SNOW Common Sense.
    I have a sisde by side with a 6' plow parked in the garage. I am my own plow guy.......... it's getting old...... however I keep up...
  • Scott Danforth
    Scott Danforth reacted to Bondo's post in the thread Which exhaust manifold gasket? with Like Like.
    Ayuh,...... Either of those shown will probably work, just fine,..... But, in My book, if you want the best available, you can't go...
  • Scott Danforth
    Agree with Bondo that manifold and elbow is toast
  • P
    Pmt133 replied to the thread SNOW Common Sense.
    Every storm has hit on my scheduled on days this year... (critical infrastructure) maybe I need to take a vacation so I can actually...
  • Ifishmuskie2
    Ifishmuskie2 replied to the thread 1969 StarCraft Transom.
    I just use tremclad on plywood it lasted over 20years. If you’re leaving the boat in the water then I’d use plastic.
  • rolmops
    rolmops replied to the thread SNOW Common Sense.
    You forgot to mention Murphy's Law.... You should contract a snow plow jockey for the season. That is a proven way to make it snow...
  • Bondo
    Bondo reacted to Scott06's post in the thread Looking for alignment tools with Like Like.
    The guys have you straight with tools needed. Only other thing I would recommend is to check your transom and stringers for rot when you...
  • Bondo
    Bondo replied to the thread Which exhaust manifold gasket?.
  • Bob_VT
    Bob_VT posted the thread SNOW Common Sense in Dockside Chat.
    I live in a snow area as many of people do but a few words of advice.............. First don't make any stupid decisions and stay off...
