B
bakerjw
reacted to
Scott Danforth's post
in the thread
Old humminbird dial flasher inline fuse specs
with
Like
you realize that for under $50 you can get a much much better unit than the old hummingbird flashers look up kayak fish finder on...
Mar 3, 2026
L
Lpgc
replied to the thread
Mercruiser 350 MAG MPI
Should be able to meaure voltages on the MAP sensor similarly to measuring voltages on the TPS as Alldodge described. Obviously there's...
Mar 3, 2026
P
Pmt133
reacted to
redneck joe's post
in the thread
2025 Splash of the Year Nominations!
with
Like
I nominate this one, 10 years.... https://forums.iboats.com/threads/1973-starcraft-ss-restore-in-progress.588902/
Mar 3, 2026
L
Lpgc
reacted to
JustJason's post
in the thread
with
Like
The appearance of an engine running rich can be caused by low engine compression. Before throwing money at this, check the compression.
Mar 3, 2026
L
Lpgc
reacted to
alldodge's post
in the thread
with
Like
If throttle is moved move 3/4 to full throttle the ECM shuts off the injectors, so if it was flooding this should allow it to start if...
Mar 3, 2026
Fun Times
reacted to
crankbait cowboy's post
in the thread
1973 starcraft ss restore in progress
with
Like
I got her splashed in august,after over ten years , and some adversity along the way
Mar 2, 2026
redneck joe
Mar 2, 2026
redneck joe
reacted to
in the thread
with
Like
Mar 2, 2026
F
fishbait2
Repainting a 1989 Crestliner Sabre G/L outboard
My boat is trailered
Mar 2, 2026
F
fishbait2
What paint do you suggest?
Mar 2, 2026
F
fishbait2
Yes I have painted cars. I wanted to roll and tip paint the boat. So far I am puzzled why not more paints are not both top and below the...
Mar 2, 2026
R
ROY WILLIAMS
reacted to
tank1949's post
in the thread
Replacing Bravo 1 lower shift cable
with
Like
Thanks, trying to access transom assembly inside is difficult at best. What is the best clamp for shift bellows. Manual shows metal...
Mar 2, 2026
T
tank1949
Mar 2, 2026
Bugzilla46310
reacted to
redneck joe's post
in the thread
New Winch or Winch Strap?
with
Like
A good wench always make a difference....
Mar 2, 2026
crankbait cowboy
Mar 2, 2026
