R
replied to the thread
Check/Fix/Replace Starter Motor 1996 50hp
The ignition and kill circuit have nothing to do with starter performance.
Mar 5, 2026
dingbat
Continuity test only tells you if the motor is shorted to ground. Tells you absolutely nothing about the integrity of the windings...
Mar 5, 2026
dingbat
reacted to
racerone's post
in the thread
with
Like
it will be way less then 200 for a meaningless no load test
Mar 5, 2026
C
Crosbyman
I don't really know where you are at here but rightly or wrongly I can't see how the ignition /kill circuitry would contribute to...
Mar 5, 2026
R
Mar 5, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Mar 5, 2026
M
MikeSchinlaub
Boats from work.
No, that's just tape holding the carpet on.
Mar 5, 2026
L
Lpgc
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
More transom work . . . I am planning on a top cap of 1/2" rounded Coosa for the transom. But, before I added the cap I wanted to put...
Mar 5, 2026
redneck joe
Your support block is cracked. I hope it is not your emotional support block.
Mar 5, 2026
T
tphoyt
reacted to
tpenfield's post
in the thread
with
Like
Mar 5, 2026
redneck joe
Random
Mar 5, 2026
tpenfield
Mar 5, 2026
L
Lpgc
Mercruiser 350 MAG MPI
Another thought - Did you change the engine oil after the stuck open injector problem? It will have caused fuel to wash into the engine...
Mar 5, 2026
L
Lpgc
reacted to
AusFox's post
in the thread
with
Like
Hi Lpgc, Thanks for the detail!! When the engine locked up it was certainly fuel. When I take the MAP sensor out and the engine starts...
Mar 5, 2026
J
janul15
Before doing other things, I want to check the current draw when powering up the starter motor on the bench. I'm taking delivery of a...
Mar 5, 2026
