A
airshot
replied to the thread
‘91 merc 60hp hitting wot rpm??
Before spending money, is the motor performing at its peak ? Make sure carbs are wide open. Buy a cheap portable tech and see if your...
Apr 9, 2026
A
airshot
reacted to
jimmbo's post
in the thread
with
Like
Before you go spending any money on Props, what condition is the Engine in? Have you done a Compression Test? If yes, what are the...
Apr 9, 2026
A
airshot
Is my motor sitting to low?
Can't tell much from the pics....
Apr 9, 2026
A
airshot
reacted to
Lou C's post
in the thread
Trailer tires.
with
Like
I think that's common, the rubber is starting to oxidize and dry out and becomes stiffer, so you lose grip. Especially noticeable in wet...
Apr 9, 2026
A
airshot
reacted to
Pmt133's post
in the thread
Trailer tires.
with
Like
Michelin defenders. Expensive but seem to be one of the few I get my money's worth out of. Had a set of hankook tires on my 04 that went...
Apr 9, 2026
A
airshot
Boat Cover Repair?
While it won't be pretty, get a piece of heavy fabric and some flexible water proof glue. Glue a patch to cover the tear and spread the...
Apr 9, 2026
I/O (Sterndrive) Conversion to Outboards
I got the idea from an old salty sailor about 15 years ago.
Apr 9, 2026
dingbat
Just thought I'd share a nice photo.
Bluebirds used to flock to our front field back when it was used as a tree nursery. Still see them, just not in the numbers seen before.
Apr 9, 2026
flashback
reacted to
Scott Danforth's post
in the thread
with
Like
Unlike the Mars rover design team. most engineers use about 3 or 4 units of measure depending on the customer. And get the conversions...
Apr 9, 2026
flashback
I've also used the allen wrench trick when mounting hardware on a balsa core deck on my old sailboat, it works well.
Apr 9, 2026
J
jetkit
reacted to
alldodge's post
in the thread
1999 Mercruiser 4.3 cool fuel pump pressure
with
Like
Thanks for the update and good to here your up and running Dead heading a fuel pump should not damage it, Merc even has a test...
Apr 9, 2026
R
Pontoon boats are different;-----Test run and post what happens.----Or why the concern?
Apr 9, 2026
M
mike_i
Boat Cover Repair?
I tried the iron on patches once but they eventually peeled off.
Apr 9, 2026
frustratedboater
posted the thread
Timing Q w/ 07 Suzuki df250z 4-stroke
in
Yamaha & Suzuki Outboards
Greetings, I have a timing issue with my 2007 Suzuki df250z 4-stroke and wanted to clarify with you all on a particular step in the...
Apr 9, 2026
S
saltchuckmatt
Ruh-Roh… a new gear case may be in order
Yes, more than enough.
Apr 9, 2026
