W
wn6ngp
replied to the thread
My carb is obsolete.. Please help me repair/replace!
Just fyi, I have 2000 90hp elpto. I started off using gasohol. In about 2010 I started having problems. I cleaned the carbs and all...
Apr 16, 2026
T
Toddavid
Power steering fluid in bilge?
I winterized it the same way as I’ve done for the last 10 years of ownership. It’s closed cooling, so I hook my 5 gallon pink stuff...
Apr 16, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I made the mistake of touching an area of the fiberglass that had been ground . . . ouch . . . microscopic fibers in my finger :oops...
Apr 16, 2026
P
Pmt133
Mercruiser motor swap
I ran a 19 for cruise which was a bear with a full boat, but still got 45-4600 wide open with load. Tubing was a 17p 4 blade and it was...
Apr 16, 2026
Ted, you still have grinding to do. you are not completely thru the gel yet
Apr 16, 2026
M
Mc Tool
reacted to
Bugzilla46310's post
in the thread
Motor support racks
with
Like
If the combined center of gravity stay within the perimeter of the base, an item will not fall over.
Apr 16, 2026
redneck joe
reacted to
tpenfield's post
in the thread
with
Like
Interior grinding is done. I still have the grinding outside the transom to do . . .
Apr 16, 2026
redneck joe
reacted to
beta's post
in the thread
1995 Crownline 202BR Restore
with
Like
FYI... got an answer from the engine forum. It's 92-25234 Sound blanket glue, but this has been superseded by Bellows adhesive 86166Q1...
Apr 16, 2026
redneck joe
Exhaust to Gimbal Connection
Lower shift cable as well?
Apr 16, 2026
redneck joe
reacted to
beta's post
in the thread
with
Like
Thanks! I also see it now in the materials list but no mention of it in the instructions. There was a good bit of whatever was on it...
Apr 16, 2026
tpenfield
Apr 16, 2026
Scott06
yes I'm a big guy and the boat could pull me up on two skiis just fine. This was with a 16" pitch 4 blade Michigan Vortex. Ran a 18" 4...
Apr 16, 2026
nola mike
reacted to
alldodge's post
in the thread
Alpha One Gen II Lower Unit - Drive Shaft Binds When Tightening Retainer
with
Like
I'm having trouble following your comments, maybe it's the terms This is talking lower You pulled the lower apart but did not...
Apr 16, 2026
nola mike
reacted to
Scott06's post
in the thread
with
Like
the 5.7 is the gateway drug to the 383...
Apr 16, 2026
Not so sad boater
No spark 55 HP Evinrude triumph 1969
I did that last night I did not see spark escaping from anywhere. What I have found is a slight wiggle on my rotor when fully seated...
Apr 16, 2026
