dingbat
replied to the thread
Too Much Prop Issue?
Why does a motor with probably less than a couple hundred hours of run time need a new long block and manifolds? A prop buys you...
Apr 25, 2026
jimmbo
18ft Boat Launch with RWD Suburban
Told this Guy, to use the other Ramp, not this one which is only good for Canoes...
Apr 25, 2026
dingbat
Better ramps or better boaters? Nobody in their right mind would consider backing their tow vehicle into saltwater to launch. It’s...
Apr 25, 2026
R
If you are looking to buy this boat then ---" buyer beware" ---I say.
Apr 25, 2026
T
tphoyt
reacted to
Scott Danforth's post
in the thread
There almost here
with
Like
A bit of humor
Apr 25, 2026
A
airshot
Water logged foam....it can add hundreds of pounds of water soaked up by the flotation foam under the floor. How old is the boat ...
Apr 25, 2026
A
airshot
reacted to
racerone's post
in the thread
with
Like
Agreed, on more than one occasion, have folks offered help to retrieve my boats.---I politely declined.----I just submerge last roller...
Apr 25, 2026
A
airshot
You are correct, however there are ramps that are shallow or the water is low etc that does require getting the back tires in the water...
Apr 25, 2026
9
995jim
posted the thread
which order to do maintenance
in
Mercury MerCruiser Sterndrives & Engines
Hi, Its time to pull the bravo1 lower unit and grease the gimble joint and also do a lower unit oil change. any advise on which to do...
Apr 25, 2026
P
Popeye303
Thanks for the reply. Long block and exhaust manifolds replaced and carb overhauled in Dec 2022 by a boat shop. Had maybe 20 hours on...
Apr 25, 2026
dwco5051
reacted to
in the thread
Hot water heater
with
Like
Electric tankless water heaters have 3+ high current elements in a manifold, hence the need for a much larger electrical service
Apr 25, 2026
dwco5051
reacted to
flashback's post
in the thread
Hot water heater
with
Like
Likely the existing 240v circuit, if existing heater is electric, will not be sufficient.
Apr 25, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Installation Update . . . I got the extension bracket aligned with the different (0.45") spacers. As such, I drilled the 'pilot' holes...
Apr 25, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
with
Like
The center stringer support is done. I do plan on putting in a floor of some sort to make for a decent storage area. The new stringer...
Apr 25, 2026
R
Apr 25, 2026
