J
Jmunk
replied to the thread
I/O (Sterndrive) Conversion to Outboards
I find it amazing how strong fiberglass and resin can be when combined.
Yesterday at 8:22 PM
A
airshot
Which kicker mount to install?
I would not trust just bolts and nuts as they could pull thru the fiberglass. Some type of backing plate will still be highly recomended !
Yesterday at 8:08 PM
K
KD4UPL
24v Battery Charging Options
How long is a string? If you have 100 Ah batteries making your 24 volts and they're down half way that's 50 Ah to put back. If you have...
Yesterday at 7:49 PM
C
Cdn20valve
posted the thread
Quicksilver 44357Q2 Through Gear Case Flushing Kit
in
Non-Repair I/O and Inboards
https://www.amazon.ca/Quicksilver-44357Q2-Through-Gear-Flushing/dp/B000XBOUIY/ref=sr_1_2?sr=8-2 Is this kit worth the higher price then...
Yesterday at 7:29 PM
R
Spark on only one cylinder- 1997 Evinrude 50HP BE50TLEUC
Orange / blue stripe fires the top cylinder.----Orange / green stripe fires the bottom----Blue is the sky ( top ) , green is the bottom...
Yesterday at 7:20 PM
C
carlos515
Question on cap removal
Ok thanks, What would a 20ft bow rider cap roughly weigh? Perhaps a few Hangman scaffolds Like Chris1956 suggests would be a better idea.
Yesterday at 7:15 PM
S
SunnyD1964
posted the thread
1964 Traveler I Think
in
Boat Restoration, Building, and Hull Repair
Is this normal after you sand off the paint? This is my first restoration.any advice is greatly appreciated and welcomed, trying to...
Yesterday at 7:12 PM
M
MikeSchinlaub
Be very careful with just 2. That leaves a lot of room for flex, and the cap isn't very rigid when seperated from the hull.
Yesterday at 7:09 PM
M
MikeSchinlaub
1981 Springbok 18' Restoration/Renovation
Aluminum boats have square sheets of aluminum screwed to the bottom of the floor under the pedestal locations. I would suggest this, as...
Yesterday at 7:08 PM
M
Mc Tool
How does it work then .....roughly 😃 always keen to learn 🙂🙂
Yesterday at 6:59 PM
M
Mc Tool
reacted to
racerone's post
in the thread
with
Like
Wrong assumption.
Yesterday at 6:58 PM
C
carlos515
Unfortunately my trailer is a roller one. My hull is dimpled from the rollers as it is. I have been building a cradle to support the...
Yesterday at 6:51 PM
Ifishmuskie2
I had this problem. I put an extra layer of 1/2” plywood 20” square under each seat. I used toggle nuts to attach the seat bases after...
Yesterday at 6:45 PM
T
TXGlastron
Glastron GXL 235 anti siphon valve location?
I have circled the part I’m wondering about. I have unscrewed without issue the brass fitting. However, the square aluminum looking...
Yesterday at 6:38 PM
roscoe
35hp choke linkage hookup?
Correct. I just checked my 35 hp, and that is where it connects. From what I can tell, this spring just holds the choke open when it is...
Yesterday at 6:37 PM
