replied to the thread
How to rotate mercruiser 3.0 manually
Please read our rules, don't post in threads more than 90 days old
Friday at 6:49 AM
W
Wrenchstench92
reacted to
Scott Danforth's post
in the thread
1971 Silverline Comoro 16.5
with
Like
generally the center was the ski locker or ski locker and a floor cooler. any limber holes cut in the stringers or bulkheads for water...
Friday at 6:44 AM
B
Bman2895
Mercury 850 85hp. Good engine or stay away?
Prop pitch is 19 also
Friday at 6:35 AM
T
tphoyt
Battery not charging.......
I have a manual somewhere for 02/03 40/50hp I’m not sure if it would be of any help but if you need any info out of it let me know.
Friday at 6:19 AM
JonBoat55
How to tighten up rack/pinion slack in steering
Y Yeah, under power it's a non-issue. Just thought if it was a simple fix, having tighter steering would be positive. Good info...
Friday at 6:18 AM
JonBoat55
reacted to
Stinnett21's post
in the thread
with
Like
I replaced my cable a few years ago due to wear. The amount of play did not improve. I think it's inherently a bit sloppy. Thankfully...
Friday at 6:17 AM
C
Captain_Rick
i am in the same spot here. finally got the crank to rotate, but not a full rotation without forcing it. before i remove the head, is it...
Friday at 6:13 AM
reacted to
in the thread
2012 4.3L TKS removal form boat
with
Like
with ANY I/O boat engine except the old OMC's pull the drive (you should be doing this for yearly maintenance) disconnect the battery...
Friday at 5:40 AM
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Friday at 5:33 AM
redneck joe
Random
Friday at 5:15 AM
reacted to
Pmt133's post
in the thread
Water in gear oil... (Not a great day)
with
Like
It's not a ton, but it was all through the drain of the lube so that's enough. Was originally planning on doing the impeller and other...
Friday at 5:11 AM
redneck joe
Random
Friday at 5:11 AM
Friday at 5:08 AM
Trim Pump Bench Bleeding?
do you have the reservoir installed? and filled? the oildyne 108 is a very very simple pump. however if water sat in the pump for a...
Friday at 5:04 AM
Friday at 5:01 AM
