D
DeepCMark58A
reacted to
redneck joe's post
in the thread
Random
with
Like
Jul 19, 2026
D
DeepCMark58A
replied to the thread
Really dry around here
It is dry here in Central Minnesota, they are having rain masses at churches.
Jul 19, 2026
D
DeepCMark58A
reacted to
aspeck's post
in the thread
with
Like
Northern Lakes are safe to swim in ... mostly ... maybe some bacteria, or a water snake that isn't poisonous, just aggressive. Muskies...
Jul 19, 2026
C
cleve
Tachometer/Regulator Question
I haven't tested this yet but I did go out again Thursday and rode about an hour or so. Battery was good and strong and engine fired...
Jul 19, 2026
I
icatchfish
1972 evinrude 50hp 2 stroke. Crank no start.
So I also swapped the 5 and 6 wires from that box to see if that would chase the spark (2 and 3 wires stayed 2 and 3). Spark stayed the...
Jul 19, 2026
I
icatchfish
Swapped the cylinder 1 and 2 wires in this box here. Spark followed to cylinder 1 accordingly and cut off at cylinder 2. So ignition...
Jul 19, 2026
O
OFF SIDE
Mercury 50 hp timing issue.
Find attached is what a believe are the adjustment screws for the timing. Can anyone indicate what the screws are ? Low idel , high...
Jul 19, 2026
jimmbo
Swap the Coils, to see if the Problem moves with the Coil Good Spark? Can it jump a 3/8" Gap?
Jul 19, 2026
I
icatchfish
Bed liner for fiberglass hull
Oh 100%. I will be installing new floor and a proper bildge eventually. If I can solve some other issues first.
Jul 19, 2026
I
icatchfish
Can now confirm, no spark cylinder 1. Good spark on #2. Swapped the two plugs to confirm and it's definitely a cylinder 1 issue. Do you...
Jul 19, 2026
I
icatchfish
I just finished checking tdc and I'm good. Basically perfect. Some jackoff stole my good sockets from my van and I don't have one big...
Jul 19, 2026
R
Remove sparkplug for #1 Turn flywheel.----See if timing pointer is near TDC.----Slow cranking speed means that there is no spark.----So...
Jul 19, 2026
I
icatchfish
Just had to Google that. I'm only moderately good with wrenches. Learn by the seat of my pants kinda fellah. I'll give it a go. Can't...
Jul 19, 2026
redneck joe
wear a life jacket
Jul 19, 2026
R
Check flywheel key.
Jul 19, 2026
