Dukedog
replied to the thread
May Day help
pump tha "bulb" when it starts ta act stupid.. if that works then its bad.. next push tha key "in" (activates tha enrichner circuit) and...
Wednesday at 1:40 PM
metalchewy
reacted to
redneck joe's post
in the thread
Building a fishing boat.
with
Like
i was going out yesterday until the daughter called and told me she had a plumbing leak. today is new electric panel tomorrow? Heres...
Wednesday at 1:32 PM
190Marco
posted the thread
2003 Johnson 115 – Vacuum/Bypass Hose Diagram & Check Valve Elbow (P/N 0437784) Question
in
Johnson & Evinrude Outboards
I bought a used 2003 Johnson 115 that never ran very well. I ended up replacing the powerhead with an OBR powerhead, and the engine now...
Wednesday at 1:23 PM
B
Built For Speed
May Day help
Will do thank u
Wednesday at 12:21 PM
F
Ferenc Gemesi
reacted to
alldodge's post
in the thread
Mercury 200dfi 1997
with
Like
It works the same way, only issue is will 50:1 oil mix flow correctly thru the injectors. My guess is yes but it's not my motor Mix...
Wednesday at 12:10 PM
C
How to correct positive camber
Gee, can you put the straight edge on the spindle? I would expect it to be bent down, no? I suppose it could be a loose bearing and/or...
Wednesday at 12:06 PM
Lou C
Volvo Penta 5.7 TBI still being a pain
keep at it you'll get it eventually!
Wednesday at 11:41 AM
dingbat
reacted to
Cup420's post
in the thread
Ohm specs
with
Like
Tested...ive got good spark
Wednesday at 11:31 AM
Cup420
Ohm specs
Wednesday at 11:16 AM
Cup420
reacted to
dingbat's post
in the thread
Ohm specs
with
Like
Ohm testing a coil isn't a reliable means to measure the performance of a coil. I've had more bad coils test good more time than I can...
B
Berkley1
reacted to
Scott Danforth's post
in the thread
with
Like
have you done a compression test? all cylinders near 150 psi?
Wednesday at 11:13 AM
B
Berkley1
Yes pulled the tube completely clean
Wednesday at 11:12 AM
B
Berkley1
I do not Thanks though
nola mike
1997 5.7L thunderbolt ignition. Slow crank
Only thing I don't like about removing the lags is messing around with a penetration into wood. Mine are gooped in there pretty good...
Wednesday at 11:10 AM
B
bcj.jones
Very weird Yamaha issue
Good point! My brain always wants to know the "why" but there's a lot in life that just doesn't give us those answers. Does Yamaha have...
Wednesday at 11:02 AM
