C
Crosbyman
replied to the thread
1961 Johnson 10hp QD22 timing/throttle issue
At START the cam under the magneto plate needs to be pulled back in so the the carb roller just touches it at the mark referred to...
Today at 10:06 AM
S
saltchuckmatt
Need HELP identifying motor first
A 2002 shows your rectifier so that should be fine to order parts. Best guess.
Today at 10:03 AM
S
saltchuckmatt
1100
Today at 10:01 AM
Gibbles
reacted to
IslandExplorer's post
in the thread
1974 Chieftain 25 "Adventurer" Restoration
with
Like
New roller rocker compatible valve covers just in for the ol 888. Basically have all the parts to finally get her back together now. 👏...
Today at 9:40 AM
Gibbles
reacted to
66Holiday924's post
in the thread
1978 Islander 22 I/O
with
Like
I rough sanded, cleaned, and primed the cabin bulkheads. I used tractor paint on my other boat, and it worked out well, so I decided to...
Today at 9:38 AM
1986 Mercury 9.8 110 outboard
https://www.oldmercs.com/category_s/2009.htm the service manual is $75
Today at 9:01 AM
E
electricjohn
Mercury oil injection - keep or delete?
I've check fuel lines and all still are good after 40 seasons of both salt and bland (fresh) water operation. Another problem is that...
Today at 8:54 AM
FLATHEAD
Nobody fishing?
I will say the Garmin Force trolling motor I paid a lot of money for has been giving me issues. On Monday If I had a quick release set...
Today at 8:53 AM
J
jsaylor
posted the thread
Should my telltale always be cool?
in
Crestliner Boats
First question. I have a 2001 Suzuki DF70 four stroke and my telltale always stays cold? some say yes some say no? Second question...
Today at 8:50 AM
FLATHEAD
Nobody fishing?
Not sure how many remember but that thing is pretty much a “ mister twister” . I’ve been out a couple days a week bass fishing...
Today at 8:47 AM
R
With 6 drops of fuel in each sparkplug hole it should bark like a wild dog.----If not , you do not have strong spark or spark at the...
Today at 8:34 AM
Berdink
Sputtering Johnson V4 90hp - 1994
Thanks
Today at 8:31 AM
Berdink
reacted to
jimmbo's post
in the thread
with
Like
Having the same Splines, doesn't mean it is going to fit properly.
Today at 8:30 AM
R
Throttle should not open till mark on cam touches the roller.---As it is now throttle opens too early.
Today at 8:22 AM
R
Is the powerhead original?-----Only some pictures of it might explain the missing wires going to trigger?
Today at 8:18 AM
