IslandExplorer
reacted to
pattyson's post
in the thread
How do I Remove Very stuck on Exhaust Manifold Gaskets?
with
Like
ATF works wonders unsticking things.
Aug 19, 2026
IslandExplorer
replied to the thread
Tiny boat performance help
Nice homemade hydrofoil! I bet if you trim it down a little in front as previously discussed you will gain that extra speed from a...
Aug 19, 2026
P
Pmt133
reacted to
jlh3rd's post
in the thread
Just thought I'd share a nice photo.
with
Like
raystown lake, nightime, July
Aug 19, 2026
IslandExplorer
reacted to
kalebsheridan's post
in the thread
with
Like
Aug 19, 2026
IslandExplorer
reacted to
Mc Tool's post
in the thread
with
Like
Looks similar to my "Permatrim ", NZ made out of 5mm aluminium plate . There are some here who 💩💩 them but Im liking mine , I have had...
Aug 19, 2026
IslandExplorer
reacted to
mr 88's post
in the thread
with
Like
Google, 5hp Mariner tiller extension, this will solve your planning issue by allowing you to sit in the middle seat while you plane out .
Aug 19, 2026
IslandExplorer
reacted to
airshot's post
in the thread
with
Like
You just proved to yourself that it needs weight is needed forward. The small hull is having difficulty getting up on plane due to the...
Aug 19, 2026
IslandExplorer
reacted to
jlh3rd's post
in the thread
with
Like
Aug 19, 2026
IslandExplorer
reacted to
Pmt133's post
in the thread
with
Like
This is dad. This is the second time dad has driven the boat since the restoration. This is the first time dad has driven it at the lake...
Aug 19, 2026
flyingscott
reacted to
Mc Tool's post
in the thread
Piston soaking a 2 cycle outboard?
with
Like
50:50 trans fluid and acetone is a very good penetrant /solvent that has free'd many a stuck piston . A bit if trans fluid wont hurt...
Aug 19, 2026
Texasmark
It's a "Moment of Inertia" thing......Foot-Pounds. You have the pounds in the items lifting capabilities which is constant but when you...
Aug 19, 2026
R
When do you replace the bellows? '01 Alpha One Gen 2
Is the boat on a trailer?-----In hot weather?----Is boat left unattended at a dock for weeks at a time?-----All factors to consider.
Aug 19, 2026
At your age I would replace, even more so if the drive was stored in the up position
Aug 19, 2026
J
jlh3rd
Aug 19, 2026
M
Matts5150
reacted to
Searay205's post
in the thread
Mercruiser 8.2 w/Cats & Closed Cooling Question
with
Like
A lot of bad and incorrect information on this thread. You don't have to replace the catalyst in the manifolds. they will last a...
Aug 19, 2026
