C
replied to the thread
1996 150 grease points
Look up a hydraulic steering system and see the cylinder it has at the motor. Do you have something like that? Calbe steering doesn't...
Aug 19, 2026
C
changing pitch
Generally, yes, a prop shop can do that. They will also usually stamp the prop with the new pitch.
Aug 19, 2026
J
jlh3rd
Just thought I'd share a nice photo.
little backstory. What I saw with my eyes did not have anywhere near that many stars. The Iphone's resolution/sensitivity obviously...
Aug 19, 2026
J
jlh3rd
posted the thread
changing pitch
in
Prop Questions and Topics
I'd like to have my Merc. aluminum 4 blade 14x14 prop changed to 13" pitch....there's not a 4-14x13 out there that fits my CT 4 3/4"...
Aug 19, 2026
C
Crosbyman
just unscrew the bolt to access zerks ..close up after do one side at a time
Aug 19, 2026
A
apBoatin
posted the thread
Questions about overhauling a KF-5 Mercury outboard
in
Mercury & Mariner Outboards
I’m new to this forum so forgive me for my basic questions. I was gifted a Mercury KF-5 outboard motor (5hp). I think it’s a circa...
Aug 19, 2026
A
AZ_J
Can anyone confirm to me that these are cable steer and not a hydraulic steer system? Just want to make sure before I go disconnecting...
Aug 19, 2026
K
kalebsheridan
Tiny boat performance help
Thanks! I just really didn't want to drill any holes if I wasn't confident it would work. I've seen a few no drill versions but they are...
Aug 19, 2026
B
Boatboy97
reacted to
dubs283's post
in the thread
330 black scorpion low power
with
Like
Posting test results as "ok" and "appears normal" doesn't tell us very much. If you removed and inspected all 8 injectors and observed...
Aug 19, 2026
IslandExplorer
The no drill feature is really nice and prob rare for those. The one I have requires 4 holes through cavitation plate. Theyre typically...
Aug 19, 2026
C
When do you replace the bellows? '01 Alpha One Gen 2
I would recommend a service manual, as the replacement procedure is tricky. Mark or remember the position of the hose clamps on the...
Aug 19, 2026
IslandExplorer
reacted to
kalebsheridan's post
in the thread
with
Like
Thanks! I'll very likely trim the front back so long as it doesn't affect the structural integrity. I forgot to mention, it's a two...
Aug 19, 2026
C
1992 Carver Montego SR8 - shift lever problem
You might U/L a picture of the control. Sometimes the throttle handle has to come off. Others the throttle only button. However, it...
Aug 19, 2026
T
trooper1954
Vacuum line for Suzuki 2.5HP 4 stroke outboard
It seems Suzuki canada no longer sell the hose with the metering jet installed during manufacture ... just as two separate items. Just...
Aug 19, 2026
redneck joe
reacted to
jlh3rd's post
in the thread
with
Like
raystown lake, nightime, July
Aug 19, 2026
