redneck joe
replied to the thread
When do you replace the bellows? '01 Alpha One Gen 2
at 25 years there, imo, is nothing to consider other than replace.
Aug 19, 2026
tpenfield
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
I believe those files were from when I was having EMCT overheat issues. IIRC, I solved the voltage issues in 2022. There was an...
Aug 19, 2026
K
kalebsheridan
Tiny boat performance help
Thanks! I'll very likely trim the front back so long as it doesn't affect the structural integrity. I forgot to mention, it's a two...
Aug 19, 2026
K
kalebsheridan
That is very similar. Yeah I do have quite a bit of mine close to the transom. I left a lot of glass so I could trim it back later if I...
Aug 19, 2026
T
tphoyt
Prop / prop shaft damage
I know a guy that had his lower replaced and somewhere along the way they disconnected the no oil alarm and the engine seized as a...
Aug 19, 2026
B
Brock96
posted the thread
1992 Carver Montego SR8 - shift lever problem
in
Steering and Controls
The Throttle Shift Lever is when changing gear very tight - it does not shift smoothly - feels like it needs to be greased or...
Aug 19, 2026
aspeck
Just thought I'd share a nice photo.
Gotta love Raystown!
Aug 19, 2026
Horigan
Has anybody painted their bilge glossy grey with the total boat epoxy?
When we repowered our Commander we painted the bilge with grey Bilgekote. It's easy to clean and very tough.
Aug 19, 2026
FLATHEAD
reacted to
jlh3rd's post
in the thread
with
Like
raystown lake, nightime, July
Aug 19, 2026
Bt Doctur
2005 bravo 3 leak but no leak
if you find it has oil on it ASK how to remove it first before you snap the plastic fitting
Aug 19, 2026
IslandExplorer
How do I Remove Very stuck on Exhaust Manifold Gaskets?
Wow, that looks like that was tough. Crazy how resilient old baked on gaskets can be. Good job not giving up. And I'd definitely...
Aug 19, 2026
M
muc
I don't have the time right now to spend the time I need, hopefully tonight or tomorrow. I do have a couple of questions for @tpenfield...
Aug 19, 2026
IslandExplorer
reacted to
KM7's post
in the thread
with
Like
I was able to get all the gasket material off the engine block. Here was the method: 1) Vacuum all around the exhaust and the spark plug...
Aug 19, 2026
IslandExplorer
reacted to
Chris1956's post
in the thread
with
Like
Cast iron cylinder head? If so, they are pretty tough, unlike aluminum. There are stamped steel "holders" for single edge razor...
Aug 19, 2026
IslandExplorer
reacted to
Lou C's post
in the thread
with
Like
Or a 50/50 mix of ATF & acetone.
Aug 19, 2026
