V
Vladimirchaparral267ssx
posted the thread
Serious Hard-Top Structural Failure – Chaparral 267 SSX (2025)
in
Chaparral Boats
Hello everyone, I am posting here because I would really appreciate the opinion of experienced Chaparral owners, marine technicians...
Aug 22, 2026
replied to the thread
Woods 9180RD Batwing came apart
As before im not a welder but usin .045 flux wire and running setting 4. Ground a grove down the Crack then more passes . Ground some...
Aug 22, 2026
Fun Times
reacted to
alldodge's post
in the thread
Mercruiser Cool Fuel Module (Gen III) cooling passages routing question
with
Like
Haven't looked at one close enough but I would say none of those holes should be open to the fuel @muc can you advise? Could use...
Aug 22, 2026
puffitu
posted the thread
2006 Nisan 30hp 4stroke ecu
in
Honda & Tohatsu/Nissan Outboards
Probably a long shot but does anyone happen to know where to obtain part number 3ac064014m or 3ac06401 ecu ? Thanks in advance.
Aug 22, 2026
Fun Times
reacted to
muc's post
in the thread
with
Like
Pretty sure that bolt hole shouldn't be open to the cooling water passage and a dealer would recommend replacing the entire module. If...
Aug 22, 2026
D
damo79
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
Unfortunately the boat is back on trailer, my 2 paid months in local marina are over. Wish I tried that test on idle when the boat was...
Aug 22, 2026
T
tphoyt
reacted to
DeepCMark58A's post
in the thread
cooking
with
Like
I was wrong I have the orange so it is chicken of the woods vs hen of the woods. I marinated them then smoked them then seared at the...
Aug 22, 2026
Berdink
reacted to
grzzzz's post
in the thread
fuel tank
with
Like
Re: fuel tank I put mine under the deck of my 66 Starcraft holiday. Saved a lot of room. It is a Moeller FT1826 18gal and I bought...
Aug 22, 2026
Fun Times
What is this cable? Should it be attached?
If you’re able to maybe locate an fuller? engine type serial or model number on your engine, it may help to find and confirm your exact...
Aug 22, 2026
J
Jamz33
2003 5.7 Volvo Penta water in oil
Once I pressure test the engine, if there is an issue with the block, head, or head gasket, would I be able to determine which one is...
Aug 22, 2026
J
Jamz33
Ok thanks for the reply
Aug 22, 2026
P
Pmt133
reacted to
alldodge's post
in the thread
with
Like
Welded up a piece on pin and installed. Did get some penatration and doesn't look the great but good enough . I started developing...
Aug 22, 2026
F
findinghomer
Question regarding wiring up a carter electric fuel pump
Thanks Mike! This has been the biggest headache of my engine swap. 😂
Aug 22, 2026
F
findinghomer
reacted to
nola mike's post
in the thread
with
Like
yes
Aug 22, 2026
M
muc
Aug 22, 2026
