redneck joe
reacted to
nola mike's post
in the thread
Stingray
with
Like
Why do we have separate fresh and saltwater forums? Where's the love for brackish? The boy caught a decent sized stingray. I've never...
Aug 22, 2026
flashback
replied to the thread
Thinking of getting a sailboat . . .
Guessing you're going to set it on some jack stands to get to the bottom and remove keel.
Aug 22, 2026
flashback
reacted to
alldodge's post
in the thread
Woods 9180RD Batwing came apart
with
Like
As before im not a welder but usin .045 flux wire and running setting 4. Ground a grove down the Crack then more passes . Ground some...
Aug 22, 2026
320 Sea Ray
Should never hear any noise when turning, either U joints, gimbal bearing or both. Next question is when was last documented bellows...
Aug 22, 2026
Berdink
1994 140hp v4. Hard starting and intermittent rough idling and dying.
Every motor seems to be slightly different, but for mine I have to raise the throttle handle up about an inch and a half, and then just...
Aug 22, 2026
G
garrettbirkhoff
posted the thread
Trying to identify 2000 Johnson/Suzuki 50 HP (J50PLSIB)
in
Johnson & Evinrude Outboards
Hey all, I am tearing my hair out trying to get parts and a manual for the outboard we have. It is a Johnson 50 HP four-stroke...
Aug 22, 2026
Berdink
reacted to
racerone's post
in the thread
with
Like
It is elegantly simple to work on these starters!----Nothing to them.----Just 2 bolts to take out.----Scratch the upper and lower parts...
Aug 22, 2026
Berdink
reacted to
Crosbyman's post
in the thread
with
Like
one HAL 9000 opinion...fwiw POST YOUR MDL # Yes — on the 1994 Evinrude E140CXERE carbureted V4, that combination of hard starting +...
Aug 22, 2026
Berdink
Sputtering Johnson V4 90hp - 1994
Here she is running at 38mph, 5400 RPM WOT on a 1967 18-foot StarCraft Holiday with 3- 200 pound guys and our ice chest and gear. . Near...
Aug 22, 2026
nola mike
reacted to
jimmbo's post
in the thread
Prop nut for Merc 25 hp?
with
Like
Lots of SS Props and AL Props use the same Prop Nuts, so who knows....
Aug 22, 2026
nola mike
Stingray
And he and his buddy just caught 13 croaker, and we caught a couple dozen crabs for tonight, along with a bunch of tomatoes and...
Aug 22, 2026
tpenfield
Here is my boat (O'Day Mariner 19) . . . it is waiting for its turn at the restoration process. I've put together a preliminary budget...
Aug 22, 2026
2003 5.7 Volvo Penta water in oil
If you have a problem with the block and heads, you follow the sound of the escaping air. Remember air tests must have all the water...
Aug 22, 2026
O
ostrichegg
Mercruiser Cool Fuel Module (Gen III) cooling passages routing question
Thanks! Let's say it doesn't leak. Is there any downside to running it like this, with perfect seal? Is that generally pretty good...
Aug 22, 2026
O
ostrichegg
Thank you! Luckily, I don't think the bolt hole is open to the fuel, just to the raw water cooling passages. And I run in salt, so...
Aug 22, 2026
