nola mike
replied to the thread
Retirement Financial Planing
So as much as I hate taxes, I figure that if I'm retired and trying to avoid the 37% tax bracket, I'm doing alright. That's more money...
Aug 23, 2026
C
camboat
Switching from Volvo TBI to Carb on a 1996 5.7 GI
Today I went out crabbing for 3 hours. No oil burn from yesterday and today. I’m going to install a catch can system to each valve cover...
Aug 23, 2026
Grub54891
reacted to
redneck joe's post
in the thread
Trail Cam pix......
with
Like
Our little family group. Been with us all year https://www.facebook.com/share/v/19BrQZSveE/
Aug 23, 2026
K
KM7
What is the Best Way to Repair the Snaps on a Sunbrella Cover
There are a lot of missing snaps, so I'd prefer not to have to sew on a doubler. There should be a strong adhesive that I can use to...
Aug 23, 2026
K
kalebsheridan
Deep pitting inside water jacket on power head.
Huh, never though about anodes inside the motor. I know about the one above the prop.
Aug 23, 2026
T
ttles714
posted the thread
remote motor control on-off-start
in
Yamaha & Suzuki Outboards
I am looking to start, run and stop my 2007 F250 from behind the engine when it is on the trailer, I want to avoid having to go to the...
Aug 23, 2026
Stinnett21
Alpha 1 gen 2 shift does intensity of ratcheting matter
Great I'll try this. Thanks muc! The boat is 1.5 hours away so I may be a bit.
Aug 23, 2026
M
Mc Tool
1st thing I would check is the state and mounting integrity of any sacrificial anodes that may be inside the water jacket . 🙂
Aug 23, 2026
M
muc
If you’re sure on the 6”. Adjust the shift cable from the helm to get the ratchet right. Shouldn’t be more than 1/2 way up the slot with...
Aug 23, 2026
Stinnett21
I have manual 14 and I've read those parts. I also watched Chris' YT video and tried to do exactly as he does. I just don't understand...
Aug 23, 2026
Alumarine
reacted to
Bt Doctur's post
in the thread
NLA shift interrupt micro switch
with
Like
Should your switch go bad/not working you can update to the newer style with a small wiring mod. Remove and tape off the Green /White...
Aug 23, 2026
F
findinghomer
Question regarding wiring up a carter electric fuel pump
Yes I understand that, I was confused about how the starter doesn't get 12v back feed from the purple wire, When I'm done turning the...
Aug 23, 2026
F
findinghomer
reacted to
flashback's post
in the thread
with
Like
My 95 v8 had a mechanical pump until a few years ago when it started puking and I then installed electric.
Aug 23, 2026
F
findinghomer
reacted to
Lou C's post
in the thread
with
Like
From what I was able to determine, the last use of the mechanical fuel pump was on the 4.3 V6 blocks made from 1987-1992, from '93 on up...
Aug 23, 2026
F
findinghomer
Bc I had to repower, and I upgraded to a vortec engine, And unfortunately it's not machined for a mechanical fuel pump
Aug 23, 2026
