G
garrettbirkhoff
replied to the thread
Trying to identify 2000 Johnson/Suzuki 50 HP (J50PLSIB)
I don't see any rise, or any change as the motor shifts from idle to ~2500 RPMs. So now could the problem be in the rectifier, or in...
Aug 24, 2026
Bt Doctur
2001 Mag MPI Alpha lugs
sounds like you replaced a 5.7 with a 5.0 and you lost about 60 horses
Aug 24, 2026
C
remote motor control on-off-start
They have remote starter cables for Mercs and other motors. Mechanics use them on motors mounted on stands. You might look for them...
Aug 24, 2026
O
OnThePontoon89
1989 3cyl 75 HP Evinrude - Running on One Cylinder? (Videos Included)
Obviously I have to heat shrink them but look at the old terminals. These are for tilt\trim (a pin broke) but the others were similarly...
Aug 24, 2026
C
Deep pitting inside water jacket on power head.
You can epoxy the pitted areas. If you clean the metal, wipe it with acetone and use Marine-Tex to fill the pits, it will add some time...
Aug 24, 2026
W
workboot
200hp efi overheating
I changed the spark plugs about 2 months ago, all were the same color. There was no water in any cyl.. I also borescoped all cyl. and...
Aug 24, 2026
C
Any clue what this gunk is?
Gee, smell the stuff. If it is gear oil, it will stink from the sulfur in it. If it is 2 cycle oil, it will smell like gas or oil.
Aug 24, 2026
C
White gelcoat restoration
White gelcoat usually holds up well. The darker colors are the ones that get chalky. Also, gelcoat doesn't have a clear coat over it...
Aug 24, 2026
T
ttles714
good information , pretty much what I was looking for .. I think what i am going to do is find a 10 pin harness to plug into the...
Aug 24, 2026
Let me ask another way You've had the motor for 10 years, has it "always" run like this since to motor was installed?
Aug 24, 2026
B
bakerjw
1988 THOMPSON 240 FISHERMAN REBUILD
I covered a bit of this in my previous post. I like to seal the inside first and address the filling of holes on the outer skin later...
Aug 24, 2026
B
bakerjw
reacted to
newtoboat101's post
in the thread
with
Like
1988 thompson 240 fisherman fiberglass boat rebuild transom (see pics), my question is now that i have removed everything from the...
Aug 24, 2026
B
bakerjw
reacted to
newtoboat101's post
in the thread
with
Like
hello so i have started getting materials together for transom rebuild and have sourced local coosa board ,now my question is...
Aug 24, 2026
B
bakerjw
Love to see the work! Myself, I'd go with 3/4" Coosa 30 across the board if you can find it. It is more expensive but lighter and will...
Aug 24, 2026
J
Jakecsam
posted the thread
Honda B100L outboard fuel pump ?
in
Honda & Tohatsu/Nissan Outboards
I’ve got a Honda B100L laying around my shop and it looks like the only thing missing is the fuel pump. I think the part number...
Aug 24, 2026
