nola mike
replied to the thread
My block is drained, right?
As a (very) late update... Apparently my block is fine. So... strange. Definitely cold enough that it should have cracked if there was...
Aug 27, 2026
Lou C
Sand Ingestion - DP-SM
IIRC there is a clean out on the SX upper unit, under the plastic cover. Once it gets in the engine it's tough to get it out. GM cast...
Aug 27, 2026
cupped prop question
Post #2 answered that question
Aug 27, 2026
9
99yam40
Just cant figure this out...
So it sounds like you need to fire the motor up more often to keep fresh clean fuel in the carb bowls. carb bowls are vented to...
Aug 27, 2026
C
chrisgt
suzuki prop vs turning point 4 blade prop; looking for advise
I finallyyyy got a 17p hustler 4 blade on there and.. I dunno. Up until about 22kts it gets the same, or maybe slightly lower fuel...
Aug 27, 2026
And I'll go back to my original thought, that your within 200 rpm of max now what makes you think that if you get the extra 200 rpm at...
Aug 27, 2026
ezbtr
reacted to
Pmt133's post
in the thread
rant
with
Like
First words out of my mouth "what do you need me to bring?"
Aug 27, 2026
C
cgc0408
reacted to
kccoe's post
in the thread
Sx-m outdrive separating lower and upper unit
with
Like
No Title larger pics and notice the broken raw water inlet tube that connects the outdrive to the upper raw water hose thru the gimbal...
Aug 27, 2026
C
cgc0408
reacted to
kccoe's post
in the thread
with
Like
No Title Seal on the raw water pickup tube is toast. Impellar pump sucking air while on plane.
Aug 27, 2026
C
cgc0408
reacted to
kccoe's post
in the thread
with
Like
I got the info I needed. I have a appalachian engineer outdrive jack and stand. Gently clamp lower unit down on jack and remove the 6...
Aug 27, 2026
C
cgc0408
reacted to
kccoe's post
in the thread
with
Like
Does someone have video or procedures of separating lower unit from upper unit transmission for a Sx-m 1.60 year 2003? Do you have to...
Aug 27, 2026
ezbtr
reacted to
FLATHEAD's post
in the thread
rant
with
Like
When I was 16 years old and was finally able to drive to a job. One of my first jobs was cutting grass at a huge apartment complex, 37...
Aug 27, 2026
J
jlh3rd
I said.. I want 6000 when I'm empty....not with 9 people. the question was does a cupped prop decrease rpms , everything else being equal.
Aug 27, 2026
reacted to
bakerjw's post
in the thread
Repair of door latch
with
Like
Can you get access behind it? Do you have some resin on hand and glass? I'd fabricate a backer plate and see if I could fish it in...
Aug 27, 2026
J
jlh3rd
".....and the peak of the torque curve is usually much lower than the max RPM point..." torque/rpm ....curves/graphs ...show rpm and...
Aug 27, 2026
