B
boscoe99
replied to the thread
Are Yamaha fuel filters universal?
If the Yamaha part number is not the same then the filter is not the same. The 65L-24563-00-00 filter is used in a number of different...
Aug 28, 2026
M
muc
Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
I just looked up your Ballistic prop. I'm surprised someone would recommend this prop for your application. Looks like the Ballistic...
Aug 28, 2026
Lou C
safe?
There are many variables here. Trailer weight capacity and boat weight. BTW boats always weigh more than the manufacturer specs. My...
Aug 28, 2026
M
muc
Yes, I didn't think Merc would help you much but I was hoping they might be willing to help due to you being in the EU. They always ask...
Aug 28, 2026
safe?
What are the specs of the trailer, GVWR weight capacity, length What is the weight of the 25 footer and model
Aug 28, 2026
jimmbo
safe?
How do expect any kind of answer, except No, when you ask a question like that?
Aug 28, 2026
Lou C
Replacing Risers/Elbows and Exhaust Manifolds on a Ford/OMC Cobra 5.8 Ltr
About the mating surfaces I just used a razor blade scraper carefully. Then very light sand with medium grit sanding block.
Aug 28, 2026
B
barnyard
posted the thread
safe?
in
Trailers and Towing
I have my 23 ft cutty cabin on my trailer ( tandem 14" wheels). Can i safely tow a 25' cutty on this trailer . I dont see any load specs...
Aug 28, 2026
Lou C
Questions about the set up of a Holley 4160 on a 4.3 V6
Thanks to all I’ll let you know how it comes out!
Aug 28, 2026
C
crazy charlie
White gelcoat restoration
I have had several white gelcoat boats and have got them polished up extremely well. Post a pic if you can because a lot depends on what...
Aug 28, 2026
jimmbo
Both Carbs have their adjustability Issues. In the case of Holleys, they do sell a lot of Parts to make a lot of Recalibrations a bit...
Aug 28, 2026
C
crazy charlie
Yamaha SX200 fuel filter replacement universal?
Thanks, and no I dont know the part number.I have to take a look at the old one.I have replaced it before and although I dont have the...
Aug 28, 2026
Lou C
reacted to
jimmbo's post
in the thread
with
Like
When the Primary plates are in the correct location relative to the Transfer Slots, the Secondary Plate can be adjusted to attain the...
Aug 28, 2026
Lou C
reacted to
Scott Danforth's post
in the thread
with
Like
Get the primary transfer slot set square. Since your 4160 secondary slots are up high, this is just a 2-screw idle mix carb. Get the...
Aug 28, 2026
Lou C
Yes it’s a pita but I guess that’s one difference between Holley & the QJet. So I’ll just keep at it till it’s right. This carb doesn’t...
Aug 28, 2026
