J
Jeff J
reacted to
flashback's post
in the thread
Servicing my trailer bearings
with
Like
If your gonna do one then do them all. It's a messy job. One time and done.
Sep 4, 2026
M
MikeSchinlaub
replied to the thread
Random
Subway maybe. Depends what you put on it.
Sep 4, 2026
Berdink
reacted to
redneck joe's post
in the thread
'67 Holiday 18' - Make it Usable
with
Like
skip carpet and get bunk slicks
Sep 4, 2026
jimmbo
Questions about the set up of a Holley 4160 on a 4.3 V6
If you are pushing upwards on the Rod, you are opening the throttle
Sep 4, 2026
Lou C
After adjusting the secondary throttle stop screw should there be movement in the throttle shaft if you push up on the vacuum diaphragm...
Sep 4, 2026
redneck joe
80 HP Mercury trim
never hurts to have a fuse. i'll peruse the manual to see if I can find some stuff on the limits but honestly i don't worry about it on...
Sep 4, 2026
redneck joe
Sep 4, 2026
Jim Hawkins
reacted to
Scott Danforth's post
in the thread
Smartrail / Splash Rail for Trihull?
with
Like
i was on a shake-down run on a boat with a new bulwark beach a few years bac. the water channeled past the primary door seal, in...
Sep 4, 2026
redneck joe
Random
love a rallys / checkers burger. None around here tho
Sep 4, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
Random
with
Like
Hardee's greasy? My brother, take a trip to a Rally's and behold. Just be sure you know the rout to the nearest hospital.
Sep 4, 2026
Grub54891
Gen 4 454 harmonic balancer screaming?
Grab the balancer with the belts off, see if it wiggles up or down and side to side. If so, it could be the crank as stated. Otherwise...
Sep 4, 2026
Grub54891
reacted to
Bt Doctur's post
in the thread
with
Like
if the balancer wobbles it could be a broken crank at #1 bearing cap and yes the motor will still be able to run.
Sep 4, 2026
Berdink
Beautiful Johnson Survivor
Here's that motor in a brochure
Sep 4, 2026
Grub54891
reacted to
Bondo's post
in the thread
Alpha One Gen 2 Outdrive Mystery
with
Like
Ayuh,..... Or the shift shaft seal,....
Sep 4, 2026
reacted to
damo79's post
in the thread
Alignment Tool for Aplha One Gen 2
with
Like
Found also this checking transom drawing. Not sure but seems that its either u-shape type like I have or normal washer no. 7 Still need...
Sep 4, 2026
