Lou C
replied to the thread
Fuel pressure too high, how to fix? Small block GM V8
Now that’s interesting. So it ran high pressure at times but not all the time? What is it that was changing to cause that to happen….
Sep 25, 2026
Dukedog
Having Problems with 1997 Mercury 150HP EFI V6
(y)
Sep 25, 2026
S
stew110507
posted the thread
Pressure guages
in
Yamaha & Suzuki Outboards
I have twin 2006 f150's. I have 2 guages on my console and I think they are water pressure guages. have a pic of the guages...
Sep 25, 2026
M
MikeSchinlaub
reacted to
tphoyt's post
in the thread
Random
with
Like
Square spline or triple square spline
Sep 25, 2026
A
airshot
portable fuel tank quick disconnect
I have the newer Merc quick connects and I have arthritus, especially in my hands. I have no issue with connecting and disconnecting...
Sep 25, 2026
reacted to
JustJason's post
in the thread
Shift Shaft Rubber Sleeve
with
Like
It's kind of like a dust seal, but for underwater use. It helps keep debris from collecting on top of the shaft seals, which extends...
Sep 25, 2026
reacted to
Bt Doctur's post
in the thread
with
Like
Well here`s one I could not figure out.Gm v6 mechanical pump Occasionally after about a 1 hour run I would be leaving black smoke and...
Sep 25, 2026
Bt Doctur
Sep 25, 2026
JustJason
Sep 25, 2026
Crazy happening in My area,.....
Sep 25, 2026
T
tphoyt
Random
Sep 25, 2026
Lou C
reacted to
Bondo's post
in the thread
with
Like
Ayuh,...... I believe that's the reason some mechanical fuel pumps have one of those big thick plastic spacer, 'n two paper...
Sep 25, 2026
Sep 25, 2026
M
Mc Tool
Random
The m is the dia in mm , but I have always called them double torx drive ( I know that aint the official term ) . Torx drives have 6...
Sep 25, 2026
M
MikeSchinlaub
Random
What are these M bits called?
Sep 25, 2026
