2000 Volvo Penta 5.0 replacement questions
Status
Not open for further replies.
tommays
Re: 2000 Volvo Penta 5.0 replacement questions
If the block was NOT drained how do you know the manifolds were drained as that is one BIG honking block crack :confused:
Tommays
Don S
Since you have the engine manual, go to section 11 of the manual. Page 2
Yes, you need to pull the drive. While you may have room to clear the shaft, you really take a big chance of screwing up the splines in the coupler. Plus you have to have the drive off when you put the new engine back in so you can align it.
RCSConstruction
Manual will be here on friday. Thanks Don!
RCSConstruction
Tommays
Ohh, they were not drained. Still water in them when I pulled.
So is it protocol to just get new manifolds?
Do shops magnuflux these marine manifolds?
They look pristine but I can imagine the water jackets inside may have cracked?
Thanks for the heads up tommays
Don S
If they have cracks inside that you can't see and you put that boat in salt water, my guess is it will open up and you may not notice it. Then water leaks into your cylinders after you shut it off. Sits there for a few days and you now need a new engine AGAIN
Just depends on how lucky you feel. Rather you want to use them or not.
I sure wouldn't.
RCSConstruction
I sure wouldn't.
Is this where I Bust Out Another Thousand....:eek:
New ones it is.!!!
Thanks again Don
RCSConstruction
Soo.. I went and looked at them and some blackish/carbon like water came out.........
I imagine that would not be normal? Seems to me it would indicate water in the exhaust runners.
You guys are saving my ***.
Thanks again!
P.S. I have my eyeball on a closed cooling system. An aftermarket one. I bet it's worth every penny of the 700.00???
Don S
Yep
RCSConstruction
Hey Don!!
Hey Don!!
You will find all the info on carb differences, timing, all the little stuff in the manuals. The upgrade to a 5.7 (in looks alone) effects only the decals.
The manuals you need for the 5.0 and/or the 5.7 will be.
Workshop manual Engine --------------------- 7797353
Workshop manual Electrical, Ignition, Fuel ------ 7743244
Supplement, wiring diagrams ------------------ 7743245
SX outdrive -----------------------------------3850075
Also, you can go to this link.
http://www.volvo.com/volvopenta/global/en-gb/marineengines/operators_manual/operators_manual.htm
Locate your engine model number and download an owners manual. It's the same manual for a 5.0 or 5.7
Hey Don, I hope you get this.
I have been trying to find these manuals and finally went down to my local shop and was given different numbers. I was wondering if you could confirm these numbers. I didn't order them in hopes that you could confirm these are the most current.
Workshop manual Engine --------------------- 7797353 This one I got on ebay for 20.00
Workshop manual Electrical, Ignition, Fuel ------ 7743244------They said 7797355
Supplement, wiring diagrams ------------------ 7743245------They said 7743244 and that there was another one too?? 2 supplements, what are these supplements??
SX outdrive -----------------------------------3850075-----They said I need 7743008
Your help is appreciated:)
P.S..
I have been referring to my motor as a 5.7gs pefs, I bought a marine 4bbl and with the 5.7 that makes this correct??? Would this change the manual numbers even though they are all covered under the same manuals??
This place has the best price on factory manuals in case you haven't purchased yet:
http://www.marineengine.com/manuals/volvo/volvo_penta_EF_models.html
When you buy the "Worksop Manual" they send you all the books that Don mentioned.
Fast Eddies marine is the best price for Volvo parts...18% off list and reasonable shipping...drop shipped from volvo.
Tail_Gunner
Why not have the all the part's sand blasted and then magna fluxed, am i missing something here.Absolutely not trying to stir the pot but throwing away good manifold's just because seem' crazy. Don i know your a true pro and i am not questioning your advice, but....mmmm ok is it possible fluxing will not show hair line crack's???
There was a time that was as good as blue printing is that no longer true???
Don S
77743244 Replaces 7797355 with wiring diagrams moved to suppliment publication 7743245
7743245 Wiring diagram suppliment to 7743244 which replaces 7797355 'EF' Electrical, Fuel, and Ignition workshop manual.
SX outdrive ----3850075-----They said I need 7743008
Yep, the 008 manual is the new number
RCSConstruction
Thank you Don :)
RCSConstruction
I thought it was nuts too but I do as I am told until I get a firm grasp on everything..:D
RCSConstruction
Thanks bruce. I coulda used that info two weeks ago..hahaha:D
Bookmarked and thank you for your great resource.
While it Is Possible that, Even though they were Frozen,.....
That they Didn't Crack,........
The Odds are Slightly Worse than Winning the Lottery.........
It's 1 Bet,... That I would Not take...............
Not with a Brand New Motor as the Bet...........
Pete2011
I have the same issue as described here, but I have removed the heads and manifold, without removing the stern drive. Is it too late to remove the stern drive? Is there a way to lower it directly or do I need to hook up all of the eletrical parts and lower this?
Status
