Re: 1973 evinrude 55 HP fouling out plugs
You know, you really need a manual. It's the best $35.00 you will ever spend. You need some other mantenance too.
hello dmster...
this is what 'they' told me, too. also an oe parts manual. the
Lakester Special came with the oe service manual. but i followed 'their' advice and
also got the oe parts catalog.
i read and use both frequently. when not reading them, i am studying them...
good reads and helpful.
dont forget to read the torque specs and note sequence if u pull ur own heads. i just did that to my engine. i admit, i prob got my parts a bit TOO clean...
LOL, but now bores, piston crowns, head combustion chambers, all mating surfaces and water plate passages, etc... are ready for gaskets. all head and plate bolts n threads chased with tap n dies... and cleaned with air. as soon as the paint on heads dries... guess i will button ' er up.
at first i wasnt going to do the head gaskets... but... after 36 yrs... the clamp loads have to have relaxed. any ways.. fate got in my way and i HAD to do it. oh well... glad for the experience.
go ez when undoing those small thread bolts. they may break if stuck as i found out...
http://forums.iboats.com/showthread.php?t=232709
#7
while i had serviceable compressions on all holes re: CR test... i did note some combustion chamber by-products had seeped past the metal sealing ring in head gaskets... top cyls... and showed black traces over to the water jacket side. no doubt some losses there, but imo... minimal at best. new should be better... replacing 3 head bolts, too. i plan not to paint head bolts so i can tweak the torque wrench on them and my plugs at regular intervals...
regards,
lakester
