1961 14' runabout
bipshoft
Re: 1961 14' runabout
KIR
Sweet boat, love the great photos you are providing
Cannot wait to see you get it finished
bailey
Looks like you're well on the way with the restoration. just 1 suggestion I'd like to offer, that being, place some supports across the top of the hull (2x2,2x4 or what ever you have handy) from side to side, (near the front and the back) just to keep the hull from distorting. That hull will distort over a period of time thereby making the "top deck" of your boat "very" difficult to put back on.
Bailey
keepNitreel
Bailey
You are absolutly right bailey, I will stop by home depot after work tomorrow and get some 2x2,2x4 from the scrap box. I love there scrap box, I can get the size I need for 51 cents each :D To bad they never have PT 2x2's, long enough for my stringers.
zach103
You move pretty darn fast. and your doin a really good job.. keep up the good work
redeye1962
yea, what is with the mowing the yard and not working on the boat. Someone needs to get their priorities straight.
keepNitreel
Question about transom.
The transom was cut to accommodate a short shaft. The Force I plain on using is a long shaft. Do I 1. buy a transom jack or 2. just cut the PT plywood all the way across the top like it was originally? I like the price of the second idea better :D. But if I do the second idea, how do I build up the part of the hull that was cut :confused:.
jcsercsa
Hay , well you have to re-glass the outer hull and then marine tex that !! then just glass in the transom like you would !! it would be the cheapest way out , there are a lot of guys on here that love the jackplate, i never had one of them so i cant tell you if there good or not , but number one sound like the best to me !! John
reelfishin
I would return the hull to it's factory height transom. It's already cut, so the outer glass or cap is already compromised to some extent. I'd make the new transom full height, glass in the missing areas and make a good solid aluminum cap for the transom area.
I had an older Starcraft which had the transom cut, I replaced the wood, reinstalled the cap, filled in the missing glass, sealed the top and took a section of 1/8" wall 2x2" aluminum tubing and cut and machined it to fit. I simply removed one wall of the tube on a table saw. The motor had no problem clearing the extra width and it looked great. I also added a polished outside motor place that was just larger then the engine bracket for extra protection and to eliminate any intense body work blending in the patch.
Inside the splashwell I simply smoothed over the repair flaring it into the existing glass work. I also moved the splashwell drain to the side.
Although there are some benefits of a motor plate, they do add some stress to the transom and are costly. It can be a way to gain power tilt and trim if your motor lacks it though.
pduquette
Ensign
Welcome aboard Keepinitreel !
Looks like a great project ! I've got a '61 MFG- that I've been s l o w l y restoring . Nice to have the family eagerly involved!:) The boat should fly with the 50 onthe back . The gelcoat looks pretty good , can it be buffed out to a shine? Keep up the good work !
captlee
Nice project, its going to look great when its done, keep up the good work and keep us posted.
My boat needs a few repairs.... could I get your neighbors phone number? :rolleyes: :D
keepNitreel
John, you have expensive taste and yes number one does sound like the best to me too. But reelfishin has a plain that will save me money & I like saving money:D. So number two it is! Also I forgot to mention that the cut off piece of the hull was still with the boat so this should make it some what easier right:confused: Please say right:(. And to answer the gelcoat question, the paint job is automotive paint with a clearcoat done by GUESS WHO, the Neighbor You should see all the runs :eek: Still want his number:D​
jcsercsa
OHH man keepNitreel, I guess i read wrong , i just read the post of what you wanted to do and I agree I would rebuild the transom , that the point i was trying to make when i was takling about i didnt know about the motor jack .
thanks on the expensive taste thoe !!! I wouldnt call it that just good quality !!!1 hahaha
so nope i agree with reelfishin , thats the way to go , and if you got that piece it will make it that much easyier !! so keep up the good work and keep those pics comming !! John
mthieme
Good decision.
You're not talking major bucks.
I love the lines on this boat and this will help the asthetics.
keepNitreel
Thanks John for switching to #2, now that makes it unanimous that all are in favor for #2.:D
Kinda cold here in Virginia the last couple mornings :(. I don't have a garage so it looks like no glassing will be done this year. Does anyone know the minimum temp for glassing :confused:. I had plans to fool around with the engine today anyway. This is the first OP that I've had to really mess with it since picking it up last sunday. Have to pickup a gas tank, fueline,compression tester & sparkplugs this morning. May do some more grinding later in the day. I hate grinding that mask is HOTTT:mad:​
colobiker
keepNitreel,
I like that little boat of yours. could be lots of fun. how are you going to clear up the windsheild? any ideas?
thanks for the posts... and the pics.. I am looking forward to following your progress
keepNitreel
keepNitreel,
Clearing up the windshield:confused: I saw a thread on this forum were someone used acrylic polish on there windshield (looked hazie like mine) and it was totally transparent afterward. But my windshield has soom cracks in it so I was going to replace it with one I found on craigslist for $60 but it's glass (a lot heavier than the plexie) . So before I make that move I thought I'd get some plexie glass from Home depot and make an attempt to make a templete, cut & bend it into the bracket :D
i386
I'll be watching this one. BTW that's a really nice looking engine. Enjoy your project. If you start to get burned out, step back for a while. I've been working on mine for about 2 years.
colobiker
oh.. yea.. I remember reading about you picking up a glass walkthru windsheild :redface:
I was just curious, I have seen tons of old boats with those plexiglass windsheilds.. and always like the look of those.. but wondered how do you make them transparent again??
carry on my friend.. carry on..
keepNitreel
2 YEARS :eek: I gotta have this puppy on the water by the middle of spring. No way am I going to be land locked for another summer. I do feel you on the burn out thing because it is a lot to do and to think about. If I could do it with out having to think, things would go a lot faster I belive :D
colobiker
having never done a boat, I dont know if its the same as a car or MC
burn out is omni present... I always have a pic in my mind of what I want.
and how i want it. and i love feeling the wind in my hair..(at least for a few more years)
that keeps me going, but then.. i would much rather be in my garage wrenchin than in the house.....
I am a freak like that.. much to my wife's dismay.
one day at a time, one step at a time.. you will get it where you want it.
plus.. this forum is an awsome support group.
