price check on carb. work. 35 horse Evinrude. PICS added.
tknjk
I had a hole in my fuel line that goes from the pan under the carb, to the fuel filter on the side of the motor.
The little metal nipple busted off that is attached to the carb. bowl, and the plastic piece that attaches to
the filter on the side of the motor broke off too. What is it going to cost to have a pro fix it for me? I am trying
to get an estimate to see weather or not it is going to bo worth fixing. Thanks. If you need pics lemme know.
BTW the motor is late 70ish or so.
jasper60103
Re: price check on carb. work. 35 horse Evinrude.
Hopefully the pros chime in soon. But that sounds like an easy DIY fix.
edit: The little metal nipple busted off
Oh, maybe not?
samo_ott
Photos would help :) But it does sound easy if you're mechanically inclined at all.
it would help to know what 35hp there are many.
tknjk
The plastic nipple on the bottom of this thing labeled "Filter" broke off.
Here it is zoomed out. The nipple is on the bottome underneath out of view.
This is the bottom of the Carb. This bowl is where the niplpe broke off. It was made of metal.
The line goes where this red line shows.
that is not the carb, that is the fuel pump. now if you will tell us what 35 hp it is we can tell you the correct replacement pump. atleast give us the model # off the transome bracket.
tknjk
It is a model 35902A 1979 35 horse 2 stroke evinrude. Thats all I know. I came into this boat, and don't know much about it. I am just trying to get it on the lake, and keep running into little problems. Now that I know thats the fuel pump I can replace it. I found a pump online, but I guess the main part is the carb. Am I going to need to replace the whole thing, or is there a replacement for the nipple I broke off? I found a scematic of the carb. but I can't find the little nipple thingy (I know really technical here) :D.
I really appreciate all the help. I just want to get this thing on the water, and it's getting to be a real headache.
Gary H NC
Re: price check on carb. work. 35 horse Evinrude. PICS added.
Too bad the diagram does not show the fuel inlet under the float bowl.
There must be a part number for it...
Its a plastic 90* angle fitting...?
Gary H NC
Looked on BRP website the carb is NLA....
tknjk
This is the part that snapped off from under the float bowl. Other than that you can't see anything else unless you take off the carb.
Gary H NC
That sucks......The one on Ebay was not it...
I would pull the carb and see if its pressed in or what...
May be able to fab up some kind of fitting..
Gary H NC
Will that one fit on mine??
I thought it might until i looked over the part numbers...That carb is no longer available unless you find a used one..
Gary H NC
Part number 0388278 is available,it is the whole float chamber assembly and should have the fuel inlet fitting..41 bucks dealer price..
#29 in the diagram...
let me check my shed in the morning.
tknjk
That is what I was thinking after looking at the pic for a few minutes. I found a site I can order it from new.
Gary H NC
I have a 76 55hp...i am going to part out.I will check it too...
i don't have one.
Gary H NC
Just checked.The carbs i have are similar but does not have the bracket for the choke solenoid built into the bowl housing....bummer.
