Motor overheats
tko1802
My 1987 evinrude V6 225 h/p overheats and the horn goes off after a minute and half the water pump is good water is coming out and everything. I dont no what to do?
kenmyfam
Re: Motor overheats
Check thermostats and also check the head temp with a heat gun to see if it really is overheating.
tko1802
Re: Motor overheats
The thermestat is fine i just put a brand new one in and what if it is really over heated?
SparkieBoat
Re: Motor overheats
you may have sucked some sand up into your water lines and clogged your water ports in your heads. I have heard of some people having to remove their heads and flush....you can drop your foot and connect a water line to the water tube..I cut the end off of an old hose..fit right on there.
Good Luck
Sparkie
petryshyn
Re: Motor overheats
your motor has 2 thermostats......did you change them both?
tko1802
Re: Motor overheats
ok i will try that and yes i change them both.
kenmyfam
Re: Motor overheats
Has it only started doing this since the thermostat replacement ??
tko1802
Re: Motor overheats
No it did it last season when i had my old ones in.
kenmyfam
Re: Motor overheats
When was the last time the impeller was replaced ??
tko1802
Re: Motor overheats
7 years ago but the boat sat for 5 years in storage.
kenmyfam
Re: Motor overheats
Time for an immediate investigation and change out. The amount of use does not necessarily matter over much but the rubber deteriorates with age and 7 years is a long time. You may have an impeller fin or 2 that has broken away blocking your water passages causing the overheat.
This is a "Must Do" before you consider starting the motor again.
tko1802
Re: Motor overheats
Ok thanks so you think that that is the problem? How much would one cost ?
kenmyfam
Re: Motor overheats
Don't know for sure but that is where I would begin given what you have said about it.
Keep us all posted how you make out or if you need any further help.
kenmyfam
Re: Motor overheats
If you do a tear down for your water pump service. Please post some photos of your findings. You should also flush out your cooling system to get any possible obstructions out of there.
SparkieBoat
Re: Motor overheats
yes the impeller should be replaced every few years regardless of hours of use.
They are about 20 bucks and takes about 1-2 hours including changing the oil in the foot. I use the synthetic blend. and have never had foot trouble.
Sparkie
tko1802
Re: Motor overheats
Thanks for your help took the water pump out the I.D of the water pump was .062 bigger O rings were gone and everything looked worn. Put new water pump in rain it for ten min. With no alarm and the pisser was really pumping out water. See what it does this weekend at the jersey shore.
kenmyfam
Re: Motor overheats
Glad to hear it. Good Luck and let us all know how you make out.
tko1802
bulb not getting hard
Hi i was wondering why the bulb in the boat isnt getting hard i put a new bulb in thought that was the problem but now its still not getting hard full lines seem fine
SparkieBoat
Re: Motor overheats
the fuel pump is in the motor, so your fuel bulb will not stay hard because fuel is being sucked through the line not pushed.
tko1802
alarm going off
alarm going off
Hi i have an evinrude 225hp outboard 1986 and it was running fine at full speed and when we were slowing down the motor just shut off but we couldnt get it started back up and every time we try to start it up the alarm was going off at a rapid speed but the motor wasnt even on and we got it to start for a little but we had to keep priming it to stay on but it didnt sound right need help
