Re: 1961 Starcraft - 'The whole' story
First off I would like to say hello to everyone. I just joined iboats this afternoon. I was reading the forums and read the one about the 1961 Starcraft, how it was obtained and what the plans are for it.
I am sort of in the same dilemma. I just bought a 1967 Starcraft Jupiter, a 16 footer. I want to do a restoration / clean up job on her. Although not to the point of perfection. Just fix it up and make it look nicer than it is.
Reading the forum I noticed a post by Captmills with a picture of a lime green boat in the middle of the post. This boat looks exactly like the one I just bought.
What I would like to ask is, does anyone have any literature on this vessel, or where I might be able to obtain some.
The next question is the worst one. I was tinkering with the boat today, popped the floor out and filled it with water. I wanted to check for leaks before doing any painting. Unfortunately I found 64 leaks all the way around the boat, including the transome that the previous owner just replace. So I would like to know the proper procedure to follow to make this boat water tight again. I ask because I am not afraid to admit that I do not have much experience with working with aluminum. So any and all help and advice will be greatly appreciated. Also let me know if I got a good deal on this boat or not. I got the boat, trailer, one 50hp Force motor, supposedly running, one 50hp Force motor as parts, the trim/tilt control rebuilt by someone on this site. New in the box control cables. New switch, new bow light, 12 gallon gas tank, 1 year old 1200 gph bilge pump, new seats that are two years old, and new rims , tires , hubs and bearings that are a year old and supposedly only seen the water 3 times. Thank you very much for your help, it is greatly appreciated.
