I was thinking of putting some neoprene on the top of the new fuel tank to keep the floor from touching it. Came up with a new idea. Since I'll have to use 3/4 coosa for the transom, I can cut some thin strips of that and 5200 it to the top in several places. That allows me to make it the exact thickness I need. For those that don't know, Aluminum tanks have a bad rap for life expectancy. The real issue is that some boat manufactures let wood or anything that traps water touch the tank. What I'm doing is using 5200 to glue the tank to the ribs on the bottom. 3/4 air gap on both sides and as much air gap as possible on the top. If nothing holds water against the tank, it will last a very long time.
