ilove2fixx
- Joined
- Feb 13, 2016
- 501
OK, lots of confusing information and requests...
The very first thing we need is the serial number of the drive. Around 1998 Merc changed some of the bearings...
Upper drive shaft upper bearing (earlier Gen IIs) Merc # 31-61100A1. Use Timken 09067 and 09196 (outer race and roller assmebly)
Upper drive shaft upper bearing (later Gen IIs) Merc # 31-32575A1. Timken number unknown (at this stage)
Upper drive shaft lower bearing Merc # 31-35990A1 Use Timken HM89449 and HM89410
Input shaft bearings (both the same on earlier Gen IIs) Merc # 31-35988A12. Use Timken 382A and 386A (2 of each)
Input shaft bearings (both different on later Gen IIs) Merc # 31-30894A5 (set). I don't have the Tinken numbers for these. If you have a later Gen II, please forward me the numbers on the bearings. There will be one number on the outer race and one number on the roller set. Same with the upper bearing.
Chris..........
Ok will do after I take them apart
Can I use a jaw puller instead of that bearing separator ? No autoplace has one for rent but have those 3 jaw puller ?
