Chris51280
Ensign
- Joined
- Jan 24, 2018
- 933
I just installed my transom. What I noticed is that the clamps aren't really that important. The clamps will ooze out the PB and hold it in place for a couple minutes. It will stick either way. If you clamp on the inside and the outside will be pressed by the pressure created by the wood tension, I think you will be ok. It is more that you start displacing the PB and get most air pockets out. The tabbing with the 1708 will seal the deal
