matt167
- Joined
- Sep 27, 2012
- 4,466
alrigh, i think compression is good, it has one heck of a time to get going, but once warm she is golden (only took out once due to the boat needing an overhaul)
what carbs can i get to do what you described along with reeds, i cannot find crap for this. even a piston rebuild kit. i emphasize on that cause that is what will need at some point and there is no point in sinking money into a motor i cannot rebuild IMHO
pistons appear to be NLA from the manufacture but there should be some floating around. Have a BRP/ Evinrude dealer do a nationwide search. Some places will come up. That said, if it's got good equal compression and the pistons you have zero need for a rebuild
The carbs from a 60hp 2cyl I'm pretty sure will fit right on. You could also put on the complete later 60hp powerhead. They built the engine into the 80's. You may run into the exhaust being different or things like that. If your not happy with the motor just replace it.
