*Rsf*RedNeck
Thread starter- Joined
- Sep 6, 2020
- 34
I've never owned a boat and always wanted one. A buddy at work got a new one and said he had an old pos that he didn't want to deal with anymore I could have for 1000 bucks. He thought the motor got hydro locked and towed it in a week before i picked it up. It came with a dual axle ti trailer in great shape. The boat is a 1992 beretta success with a 4.3 Mercruiser. the outdrive is an omc cobra.
I got it home and pulled the plugs and sprayed some wd40 down the holes. I put in a new duel purpose battery and tried to turn it over. It turned very slow but I didn't see any water come out. I got a new gear reduction starter and installed it. It turned over nice and fast and shot the wd40 out. I checked the compression and all cylinders read right around 160 to 170 psi. I put the plugs wich looked new back in and after a good amount of cranking it fired up and idled good. I ran it for a bit on the muffs and shut it down for the night.
Then the next day I came out to work on the rotten wood on the deck and decided to hear it run some more. It fired right up and idled smooth and after about 5 mins i started hearing a grinding sound from the outdrive. Before I could shut it down I heard a clunk and the motor abruptly died. Not sure if it matters but I never put it into gear. After reading these forums for a while I decided I better pull off the outdrive and see it'll run for a few seconds without it attached. It fired right up and idled good so I shut it off. Next, I pulled the top cover off the out bored and was surprised to see the gears were bone dry. The gears look to be in good shape but the big main bearing on the drive shaft looking thing has came apart locking up the driveshaft.
All I know about boats I've learned on here and by looking at it myself, so i don't know much. I am a decent mechanic having rebuild my 1985 4runner that I use for hunting. I've done a frame-off restoration on it, a body swap, and figured out a way to replace the 22re with the 3.4 out of a Tacoma. So I'm not a complete idiot. I haven't looked at the lower section but I'm hoping I dodged a huge bullet by only frying the big bearing. Any advise greatly appreciated.
