1988 Starcraft Mariner MR 220 V rebuild
dizzyspots
Dizzy.. question for you.
Am I seeing your pics correctly? Did you have to remove your entire motor splash pan to insert the new plywood? My transom has a cap accross the top that looks like it's all one piece like molded/welded/connected to the splash well. I have the same boat as you I believe.
YES!... The splashwell may come off as one piece..I didnt know that...I am rebuding mine and will put it back in as one piece. Just finished reskinning the new transom and making patch panels for the hull
dizzyspots
New transom is in...transom has been reskinned and patch panels for the hull...rivets on Tuesday!!
dizzyspots
Well about 250 rivets later...7 patch panels in...5200 to glue and seal...PC11 2part epoxy inside the hull....new foam tomorrow
Watermann
20210401_155027-jpg.336870
Nice work, looks like some really good patches and rivet work! (y)
Hey @classiccat you have a patch master challenger!
dizzyspots
Working on the new deck and foam...delayed by high winds almost daily...and a few dust devils thrown in for good measure...yay!
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
What kind of foam you going to use?
SHSU
dizzyspots
Extruded...not expanded...polystyrene..1" thick..on edge...rigid, closed cell..waterproof..lengthwise..on top of the cross ribs
dizzyspots
Fyi...what you see is one 4x8 sheet of 1" board...guess it's going to take 3 or 4 total...stay tuned!!
mattsteg
It'll take more than that to adequately float a 220V. I did the math, as best I could, for what the statutory requirement would be for my 22ft V5 SS (at its listed capacity/weight) and it came to like 12-13 in of foam (calculating conservatively as I didn't weigh the boat, and assumed that anything I couldn't account for was aluminum). 9 in of that were to float my powerplant and the load of the boat.
3 in of foam is under 500 pounds of flotation (or enough to float around 750 pounds of mostly-submerged aluminum). It, along with your wood, will float the hull but not be up to standards.
dizzyspots
Need some minor technical help..preparing the put the console and bench seat back in. I forgot to take measurements or pictures of where they were mounted. Would appreciate any help from the Starmada. Thank you in advance...foam and decking this week...nautolex to follow...
mattsteg
Thank you for sending that....
You're probably not that far off without needing to float an 1100 pound powerplant on top of your load capacity...however the worst thing in the world is packing full of foam...but not enough.
SHSU
Was the original design for a center console or did the PO modify it?
As I have no measurements and if nobody else chimes in, you might be able to look at your stringers and piece together where there are extra holes. Should get you fairly close to original location.
SHSU
dizzyspots
Windy every day has slowed down the foam installation...looks like its gonna take 10-11 sheets...all deck boards are cut, preserved and urethane. Tackled rebuilding trailer bunks...for rid of the old lumber and replaced with polyurethane coated 2x6 (no more carpet)...also added 3/4" HDPE sliders on the bunks...moved the console and bench seat into the garage...so I can get started on them
dizzyspots
Rivet question? Looks like replacing the factory original carpet will be much easier if I remove the rod holder brackets etc....( factory carpet was installed under all these brackets then riveted) Any idea what length rivets these would take? Didnt see them mentioned in the "rivets sticky"
