I have battery voltage at purple wires of key switch with key on and everything hooked upThen your key switch is bad
Key ON and no power to the ALT, but wiring checks out.
Kill switch must be on the Red/Purple and not the Purple like all other boats
Either that or something was missed
Connect 10 pin back up.
Turn key ON and measure power at the key purple wire
That's what doesn't make since. The wire rings out good but yet no power to the ALTI have battery voltage at purple wires of key switch with key on and everything hooked up
The kill switch should be tied into the purple. Basically the purple leaves the key switch and goes to the kill switch. From the kill switch it goes to the gauges and back to the motor as a purple. The actual wire colors from the kill doesn't matter, because they are spliced inline with the purpleLanyard switch has yellow orange tracer going in and then out.
Don't know, post a picWhat is this plug on the back of the engine that has a cover over it.. almost like its on the gimbal housing..
Seems to leave that and go to the ignition module.
If I give the solid purple wire 12v on the ignition module it'll stay running until I remove the 12v..
Yep..Don't know, post a pic
That is your answer.
Just need find why 12V is not making it to the motor on pin 5
