- Joined
- Jul 23, 2011
- 53,259
The kit you buy will have instructions and schematicsSo if I put an external alternator on it does it mean that I won’t need the regulator anymore?? And if so can you send me a wiring diagram thanks
So split the drive in half and as I predicted the top was seized tried to remove the top cap but 2 out of 4 bolts were seized what to do now ??
Ayuh,.... Find a good drive with the same ratio,....So split the drive in half and as I predicted the top was seized tried to remove the top cap but 2 out of 4 bolts were seized what to do now ??
Any other choice ??? Ohhh and can’t find anotherAyuh,.... Find a good drive with the same ratio,....
Can you kinda draw lines for the 4 wire alternator please I really don’t get it , thanks
power steering pulley on a power steering pumpSo found this pic of a 470 on the internet, question what’s this ??
buy a new SEI driveAny other choice ??? Ohhh and can’t find another
Can’t I live in the Philippines any other way ?? Maybe change the seals or bearings the unevirsal joints are smooth like butter and the shaft is peachy the lowers also peachy I think it’s this part I circled by black ok I circled by blue I think is bad not all but maybe somebuy a new SEI drive
Shipping and import is like $400They ship stuff international all the time
Yes, boats are expensive. No cheap fix. Your options are: 1. find a used one 2. Buy a new one 3. Find the parts and someone with the knowledge to fix it, 4. Buy some paddles and turn it into a row boatShipping and import is like $400
BOAT is an acronym for Break Out Another Thousand.Shipping and import is like $400
I think 3 is gonna be my choice plus I think it’s cheaper oh and btw what are the reasons why my drive got seized cus they said they ran it 1 a month so like this month they ran it the next month the drive got seized then they left it for 5 years so what is the main reason for the drive seizing up ??Yes, boats are expensive. No cheap fix. Your options are: 1. find a used one 2. Buy a new one 3. Find the parts and someone with the knowledge to fix it, 4. Buy some paddles and turn it into a row boat
