87Starcraft
Thread starter- Joined
- Sep 15, 2021
- 135
After all foam is removed, I used a combination of orange and grey nylox brushes, and stainless steel cup brushes on a cordless drill to remove all the corrosion and clean the hull. Followed with a good pressure wash (used throughout the process as well) and a 50/50 cleaning vinegar/water mixture in a spray bottle to hit all the pits and areas of corrosion. Let sit for about a half hour or so before rinsing well with the power washer again. You'll need to assess the areas of damage and either patch or plug those that go through, or skim the ones that don't require a patch with Marine Tex or similar two part epoxy. I'd then throw a coat of Gluvit or Coat-it over all areas of repair, as well as any seams and rivets that will be below the waterline. Patch should consist of a solid rivetted aluminum plate that extends beyond the area of damage and backbuttered with 3M5200. If it's just a pin hole, I'd drill it out and hammer in a 3/16" or larger solid rivet with 3M5200 to plug the hole.Does anyone have good tips at stopping this corrosion. I know I need to get the aluminum to bare metal and apply self etching primer. What is the preferred wire brush to use and is there something I can fill the pitting in with that will keep corrosion from coming back
Thanks @WatermannAlright so, the pinholes that go thru I sprayed 50/50 vinegar water on them and was shocked to see a hole appear before my eyes. I thought I messed up big time. I feel like I’m going to have pinholes throughout the entire hull ifbi do this in all the places
Here is holes from just running a nylon brush over corrosion
You need to find all the corrosion spots and see what you have to work with.Here is holes from just running a nylon brush over corrosion
I totally agree,That needs a full patch
SHSU
