1987 Starcraft islander 190v?
87Starcraft
Most likely one of many unfortunately. :( Hopefully this level of corrosion is limited to small section of the hull skin.
Oh I started pulling the foam on the port side. I was real hopeful that it wouldn’t be as bad but it seems to be worse.
classiccat
Can I use license plates and street signs for making patches?
license plates will be too flimsy and most are stamped with a pattern; you want the patch to have intimate contact with the hull...separated only by a thin film of sealant (like 5200). street signs would probably work since they're usually heavy-gauge aluminum. (y)
87Starcraft
Is it odd my boat does not have knee braces or a knee brace?
Watermann
I've used nothing but old road signs for patches, these hulls and the signs are 5052 Al so there's no difference in metal alloy.
87Starcraft
Just an update. Found all the corrosion, except what is under the tank. Hopefully there is not any but doubtful. Working on getting the tank out. 20 gallons need to come out.
Watermann
Corrosion, yeah the difference between pour in foam and the old EPS they used prior to. My 79 SS had zero corrosion inside the hull even after being used in the Great Salt Lake, 9 times more saline than the ocean.
I see guys wanting to put that pour in foam in their old tin and just shake my head, there's no talking them out of it mainly because they have a fear of sinking the boat without it.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Did someone do a restore before? See the sharpe lines lining up the rivet placements.
SHSU
gwhaling
The braces are low on each side of the main stringers. The transom on my 82 model was 3 pieces. I replaced my transom this summer. I used 10-32 truss head screws, locknuts to replace the rivets I drilled out to remove the splash well.
87Starcraft
There’s a troll on a Facebook group that is telling everyone to pour that foam back in their whole boat and under the tank.The corrosion I found is sad because it seems avoidable by Starcraft. Putting some paint and or plastic down would of prevented a lot of it.
87Starcraft
Could I get some pictures of your work?
87Starcraft
Found the last of the corrosion. Until I get the transom out
SHSU
Always fun finding those patches..... All in all doesn't look to bad though
SHSU
87Starcraft
Yes sir there is corrosion everywhere but most of it is on stringers or the ribs the hull skin damage is not as bad as I was thinking it would be.
87Starcraft
Does anyone have a trick to getting to corrosion where the hull skin and stringers meet? I feel like a dremel is the only way
87Starcraft
SHSU
Hey I must of missed your question. I believe I saw someone else’s Starcraft with the same sharpie lines. But I think the floors were redone but not the foam.
MNhunter1
Does anyone have a trick to getting to corrosion where the hull skin and stringers meet? I feel like a dreamer is the only way
The stringers are usually attached to the tops of the ribs. I always remove them as the rivets are generally loose and need some attention anyhow.
87Starcraft
Thanks for the reply. I was afraid of that lol just trying to minimize down time and take care of the necessities. But corrosion is a necessity so that’s what I will probably be doing
