sopwithcamel74
- Joined
- Aug 15, 2018
- 203
Today was an excellent day weather wise; it's a shame that I had to work inside for most of it. But I did get out to the boat during my lunch break, and again after work.
Continuing demo on the rear seat boxes and the remaining foam. Seems pretty clear that someone has tried restoring this area, as some of what I'm seeing seems very unlikely to have been done that way from the factory. There's fiberglass mat, lots of marine/construction adhesive, and off layers of wood that were very poorly glassed over.
I wish I'd swapped out to a new cutoff wheel on the angle grinder ages ago; it's really helping clear out some of the thick layups in those rear seat boxes.
I've also started the process of removing and organizing the wires and cables run up to the helm, as I intend to pull the engine soon.
Only took a couple of pics that aren't worth posting, for the purpose of helping me keep some of the wire runs documented. I suspect that I'll be redoing everything but the harness; hoping that's still in good enough shape to use.
