ROY WILLIAMS
- Joined
- Aug 8, 2022
- 458
the cylinders are water in it ..the impeller had a breakdown and the sea water ran a small amount in the heat exchanger that increased the engine heat and the head gaskets breaking down ...
that picture is the impeller is rubber cracking it and bent the fins ..
put oil in the cylinders and rotate engine is marvel mystery oil ....probably a rusted issue ,,piston rings
