Starcraft 1971'? 16' to Duck Boat Rebuild
danimal045
It doesn’t look pretty, but i cut all the ribs out with a hot knife and used some adhesive to stick em together. Finished last night. going to refit my plywood flooring and mark were i am going to have the conduit poke out for running wires before i dry fit the floor again and make sure i don’t have any high spots. After that, it’s vinyling the floor and fastening down. My steering came in yesterday and new run rail is set to be delivered from wefco todayy
danimal045
Got the rub rail put on as well as the all the caps fitted and fastened. When everything’s done I’ll do some touch ups on rivets and paint. Plywood lines up good over the foam and i don’t seem to have any high spots.
Going to pull it, give it a light sanding then Either apply the vinyl or do a layer of epoxy scuff it, then apply vinyl. I have read people doing it each way. I don’t want to half ass it and regret it, but a lot of things I’ve read have shown success with just sanding, wiping, and adhesive, i don’t know. If i do a coat of epoxy going to add a few more days until i can cover floor.
I’ve decided to run the wiring through flexible conduit i have that fits almost perfect in the chines, right above the floor. I will paint it or cover it w wood covered in the same vinyl as the floor, that will be down the road though. Still have to mock up bow battery box and rear box/seat in front of transom.
danimal045
Got the rubrail from Wefco. They were very helpful, responsive, and they made it, shipped it, and got it to me in a week. Very happy i decided to get a new rub rail vs trying to salvage the old one. Definitely tightens things up
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
I see you have the original end caps. Suggest you secure them with bolts and nuts. To many have lost them the rivet fails after a good strike on a dock or such. Once lost, finding replacement would be like looking for a live dinosaur...
SHSU
danimal045
SHSU
I can prob get one or 2 areas secured with a bolt and nut, others i don’t even know how i would
danimal045
She’s ready for vinyl. Just hit it with a coat of epoxy. Once that dries i can do it to it.
Excuse my garage. It looks like it threw up. Lol. In the middle of projects things get western. Need to take an hour and reorganize and clean up.
danimal045
Was able to grab this off fb marketplace for $40 this morning. Need to clean it up, rivet on a new face, and paint it, but i think it will be way more functional than the OG console. Gotta play w the height, I can drop it another 1.5-2” if i remove the base. The final fitting with the joiners went well, now gotta get the floor vinyled and back in and secured
danimal045
That's what I thought. I strongly urge you to use aluminum for your underdeck reinforcement joiners. The last thing you want is steel rusting under your deck, rotting things out. :)
This is how I did my underdeck aluminum joiners. ☺️
Riddle me this. After you countersink your rivets, do you use wood filler, sealant/caulk, etc to fill the divot?
I am ready to do the vinyl and need to figure out what i am to do, let glue fill the hole, etc.
I am now planning on affixing all the decking w the rivers then vinyling.
Any input appreciated
BWR1953
I used 2 part wood filler epoxy from HD slathered over the counter-bored holes, then sanded it down flat with the deck. Painted over the filled holes with deck paint and anti-skid.
BWR1953
When it was done, my neighbor buddy said that the next guy who has to put a deck on there will hate me. But! I'm leaving the boat to him in my will! :LOL:
danimal045
Thank you! Seems like a good course of action. I like that idea better than seeing a ton of dimples in the vinyl
danimal045
Got the floor riveted down, and per BWR’s suggestion, got some of that epoxy wood filler I’m gonna put down tomorrow to cover the countersunk rivets. Cleaned up the console and the face were the new face will be welded or riveted on depending when if my buddy can weld the aluminum for me. Cleaned it up to start prep for paint, then i started figuring out where inwanna mount my 4 light pods, gonna have a light bar on the front above the running rights. Probably going to dry fit the blind first to make sure they can still be used if the blind is on.
Do you guys use any thing to help add rigidity were you mount the lights through the gunwale, seems just drilling and dropping would be asking to tear the metal.
That’s about were the captains Shari and console will go. Only thing that can move is the console, as i put a piece of 3/4” under where the seat base goes and ran 5/8” bolts through both sheets into T nuts, great suggestion. Going to build a box to cover the batteries, that’s where they will be, and an anchor compartment in front of it.
Prob gonna mount a swivel eze on top of a piece of ply covered in vinyl on the livewell lid so another shooter can sit there.
Cut the floor shape out of the vinyl leaving about 2” over hang everywhere. Hopefully i can get it down in the next day or 2, then i will will
Like some real progress has been made… appreciate all the guidance
danimal045
Thank you! New face for the console welded on tomorrow, and got the blind fitted today to make sure about my light mounts, and countersunk holes filled with epoxy sanded and floor prepped for glue! Just gotta get it down
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Love the way thats looking!! I floated the idea, of building mine into a duck boat like yours, by the Admiral and she shot it down haha. Glad to see it coming together so nicely.
danimal045
New face on console welded and grinded down. Console painted. Vinyl glued down. Steering and wheel hole cut and mounted, switch panel cut out and mounted. Still have to secure the console and May get the motor set tonight and steering hooked ul. Neighbor brought me up an engine hoist
danimal045
Very nice progress! (y)
Thank you! Got the engine mounted, well mostly mounted. I’m going to have to take the bolts out, coat with sealant and out them back in. The keel seems to line up pretty well at the current height with the anti ventilation plate.
Also got the steering cable ran. Bought it as a kit with helm from Vevor. Using the measurements they said to take, i ordered a 13’ cable length…. Obviously 1-2 foot too big, unless I’m missing something?
danimal045
Looking at these for passenger seats on swiveleze mounts that can me moved around. Only plan to hunt 3x, could squeeze a 4th.
I’m torn between the color scheme, any input?
